Inside bed molle racks?
RangerRaptor
Denver
2019 Ford Ranger Lariat (previously 2012 Ford SVT Raptor)
Installed my driver side yesterday, working on the passenger side today. LineX did me no favors by spraying my tie-downs and the rubber grommets. This install would be super easy if I didn't have to cut around all the LineX to remove the tie-downs and grommets.
RangerRaptor
Denver
Installed the passenger side today. I have most of the off-road equipment ready to install, but I’m waiting on some parts to help with mounting on the MAPS panels. Also, RotoPax finally got their FuelPax back in stock.
OFC Ranger
Jack
ZR2
I plan on installing something of this nature on the back side of my storage pods on each side. It will be attached to rails so with the tail gate up I can pull the whole panel out the back and retrieve items. (more or less like any truck bed drawer roll out system)
I just don't know if I can bring myself to pay pre-fab prices or make my own molle panels from simple pieces of 1" wide steel flat bar.
RangerRaptor
Denver
A lot of places sell universal MOLLE/PALS panels in square or rectangle shapes. You could mount one or more to whatever drawer mechanism you build.
Not sure if you have ever heard of 80/20 building materials. Amazing stuff that is the erector set of the age. We use it all the time for many different projects. I made a corner mount adjustable stand for my 65” TV. Tilts, swings flat against ether wall adjacent. They have slides, hinges, corners you name it.
OFC Ranger
Jack
ZR2
Yes. Actually I used quite a few 80/20 brackets on my platform build. However I used them in a little unconventional way with standard raw materials and nuts/bolts.
Search around on the web how people use it. The creativity is mind blowing. Sliding bins, gas shock locking panels. It’s limitless. The holes in the end of extrusion material is sized to tap with 1/4-20 thread. That allows bolt together structures. We run compressed air through some of or projects through the same hole.
alan0614
Alan
Granite Falls
2019 Magnetic Lariat, 2017 GT350, 2016 Subaru Legacy
Product and Training Manager
I’ve got as ARE shell and the mounts will make it difficult to add either brand panel without cutting it. At least I think it will.
armoredpig
Joseph
VA
2019 Ford Ranger STX
Nurse
I have both swing cases.. Really wish one of the brands had one that could be installed on the front half only
armoredpig
Joseph
VA
Nurse
Much appreciated! I'm looking for the front half of the sides though, just forward of the wheel arches. So I'm still SOL for now!
I really like that putco used aluminum tho
Hank the Tank
Ross
PNW
2020 Ford Ranger FX4
Housing Case Manager, Full-time student
Installed the Valhalla Molle panel for the driver's side. Fitment is great. I used Quick Fist clamps to secure the Wavian gas can and Swiss army axe; the med-kit is held by a carabiner. Drove the truck over the most uneven sections of road I could find and zero rattle or shift from the mounted components.
