Hyper flash hell and 1 weak grille light
RangerBill
PA
Well i should have lead with that...
And what follows is the most I've been embarrassed for a while (and still had my clothes on ) normally I would just disappear and not share my stupidity but here it is ...
That stupid jumper came apart inside i guess 😒, when I used the meter with the "tone" option , nothing... ALL IS GOOD NOW !!!
I now feel like an idiot for wasting your time ! I apologize 😔... I used the jumpers so I wouldn't have to stick my fumble fingers down in there while testing, never dreamed one would be bad... sorry 😞and THANK YOU FOR HELPING ME!!!
We need to keep that part number handy incase someone else has a socket fail and doesn't want to rip out the headlight...
I think Ford is gonna offer to fix it but I dont really want those guys messing with it now...
Glad you got it working.
NotBudule2
NotBudule2
Robert
21 Ranger
Upon further inspection, I saw where the technician cut a Grey wire that doesn't even go to the socket .. another crappy splice that i tried to do better and at least crimp and heat shrink ...
Anyway, Im back on the road !!!
Just need my grille lights back now...
Bob902
St. Louis
2021 Ranger XLT
RETIRED!!!!
No more right turn, Clyde!
NotBudule2
NotBudule2
Robert
21 Ranger
So... and nobody get mad because I can't help it, but i noticed the part is listed as a "female" connector, and its "small", and its from "China" AND it saved me, sooo... its my little China girl...oh oh oh oh , little China girl,
Oh oh oh oh , little China girl 👧.
My trucks a mess without, my little China girl,
Can't safely turn left without my , little China girl , but now I hear her , loud as thunder , I just installed my China girl ,
She says "shhhhhhhhh BLINK"
She says "shhhhhhhhh BLINK"...
RangerBill
PA
Are you sure that you didn't shock yourself replacing that socket?
Chris M
Surprise, AZ
2021 Ranger XLT Sport 4X4
Security Supervisor
Pretty sure Bowie would approve!
GOOD JOB: :rockon:
I can CONFIRM you have it wired correctly but I would hit the heat shrink again to suck it up tighter on the wires (moisture intrusion)
To Clarify for others that may have this issue.
Red to Brown = Park Lights (Pin #5) Connector
White/Blue to Yellow (ish) Amber = Turn Signal (Pin #7) Connector
Green/White to Green = Ground (Pin #1) Connector
Pin #1 = Park/Turn Ground
The Grey wire that they (Cut) is Pin #8, note pin #8 is only on the Halogen Assemblies and not on the LED's - it will have a blanking plug, just like Pin #6 has in this pic.
Pin #6 is for Led Assemblies (only) DRL Power for the Led Strip
Pin #8 = Low & High = Headlight Ground (Halogen)
Pin #4 Directly below it = Headlight Ground (LED)
These 2 wires splice together in the main truck harness
So YES they cut a wire that they did not need to.
NotBudule2
NotBudule2
Robert
21 Ranger
GOOD JOB: :rockon:
Yeah that one didn't want to shrink up all the way for some reason 🤔 so I smeared some sealant around all the ends and may tape it also... if things go south again , I'll just switch out the headlights to led , kinda want those anyway ...
NotBudule2
NotBudule2
Robert
21 Ranger
Now , on to the grille lights !
Wiring looks good all the way to it but it must be loose inside... if I could find one just like it, I could replace, but those numbers bring up all kinds of different ones and now my head hurts !
NotBudule2
NotBudule2
Robert
21 Ranger
Im back baby !!!
Shout out to all that helped and special shout out to Custom Auto Works ! He found me in the system and sent out a new harness with ALL the lights ✨️ 😍 😎
Damn , 4 little leds make a big difference, love those little guys...
