Howling/Whirring Sound From Front End. Speed Dependant
RedlyrsRevenge
RedlyrsRevenge
Sean
Fresno, CA
21 Carbonized Gray SuperCab STX FX4
MH/FE Parts Salesman
Just the housing? What's making all the noise inside?
From what the write up said it was "coming from the front pinion area." The housing is supposedly damaged as well. I was told the diff comes as a complete unit.
Not sure the if the pinion is out whack and it is possibly grinding on the ring gear or housing/bearings.
RedlyrsRevenge
RedlyrsRevenge
Sean
Fresno, CA
So, my technician buddy and I crawled under at break. Dark gear oil leaking. All over the undercarriage. It is burnt and nasty. ?
Stringburner
West Virginia
2021 Iconic Silver Ford Ranger XLT Tremor
They need to come up with you a loaner at this point, even if it's a clapped out Festiva. Sorry you're having so much trouble, what a headache. :confused:
Situations like this are why I always have 2 vehicles. One is none.
RedlyrsRevenge
RedlyrsRevenge
Sean
Fresno, CA
Update 1/6- the Fordening
Service manager called me this AM after I didn't catch him in person last night when I visited the dealership again again.
He is escalating the case to Ford and putting out a request to source the part from any dealer who might happen to have one in stock. He is going to call me back (allegedly) this afternoon.
Kind of getting desperate for something as the noise is louder by the day and the seal is leaking as bad or worse than the original incident.
RedlyrsRevenge
RedlyrsRevenge
Sean
Fresno, CA
Update 1/7- Raiders of the Lost Diff
Dealership is not returning my calls. ? I talked with another dealer who confirmed that the national depot has a good amount of diffs in stock and they are NOT on backorder.
I did get a short text conversation going with the dealer who dodged my questions. I will post the convo once I get the names fuzzed out.
RedlyrsRevenge
RedlyrsRevenge
Sean
Fresno, CA
Behold! My conversation. I'm not off my rocker am I? I think I might be done with these guys. There is another dealer in the area and I'm sure they'd be happy to fix my vehicle in a timely manner.
RedlyrsRevenge
RedlyrsRevenge
Sean
Fresno, CA
Update 1/10- The Parts Department of Secrets
No contact from the dealer regarding my repair. However I called the other dealer on the other side of town. I talked with their part's department and confirmed with them that the diff is indeed backordered for my truck. They were not able to get a timeline either. They did show three available in dealer inventories across the country but, said odds are those are on reserve for other repairs.
So I guess I am going to have contact Ford customer service and complain. I've been without a properly functioning truck since 12/27. It really sucks having to keep borrowing vehicles from family.
RedlyrsRevenge
RedlyrsRevenge
Sean
Fresno, CA
Update 1/12- Diff Bound and Down
I messaged the dealership this morning via their text line casually asking if they had any updates. They sent back that they expect the diff to be in this week and if I want to schedule to come in on Monday.
So I am waiting for them to let me know what time to bring it in. I will believe it when I see it though. Going to have them change the oil as well against my better judgement but, I do have 42,000 points to spend.
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
Your problem sounds similar to what I experienced with my last Jeep. Had two factory ball joints fail and this was the VM I got from the service department after the “inspection” on the ball joints
RedlyrsRevenge
RedlyrsRevenge
Sean
Fresno, CA
I wish I had that good of communication with the service department at my dealer.
dmeyer302
Daniel
Carthage, MO
2016 Odyssey, 2021 F-150
Mechanical Engineer
If you just pull your half shafts (also mentioned way back in post 11) you can be back on the road normally without causing any further damage. What's stopping you from doing this?
Instructions in section 205-04.
RedlyrsRevenge
RedlyrsRevenge
Sean
Fresno, CA
It is is a warranty/gratis repair. They were not willing to put in additional labor into it without me paying for it.
I also do not have the time or facility to do the job myself.
Also also, I didn't want to disable the 4wd in case I had to make an emergency trip up to the mountains where my parents live. That is the reason I have the 4wd.
dmeyer302
Daniel
Carthage, MO
Mechanical Engineer
This is not consistent with what you have indicated multiple times throughout this thread.
The truck is a boat anchor anyway, right?
I'm not disputing Ford's or the dealer's responsibility to fix the problem in the end, but complaining about it here isn't going to speed up the process. I see two options here: you keep borrowing your family's cars, or you fix the problem on your own.
RedlyrsRevenge
RedlyrsRevenge
Sean
Fresno, CA
Except where he tells me it’s safe to drive on two failing ball joints!
I referring to actually getting a call from them. I can't get squeeze that out of my dealer. Should have added a "/s" for the sarcasm.
But, yeah. Failing ball joints. What is the worst that could happen? ?
