Creaking/knocking sound under driver seat at slow speed
Hickesy
It's intermittent, like not on every wheel turn. It seems to come from under driver seat. I had the shocks done recently. I can't hear anything at high speed. Is this something I should get checked out at dealership? Or any idea what it might be? Edit to add: 21 Scab, 41k miles, no issues to date.
Probably just your assigned Truck Gnome screwing around with you.......
Little known fact is that every Ranger comes with an individually assigned Truck Gnome at the factory. Ment to screw around with you at any moment. time, or location....
They have numerous hidey spots throughout the truck, and can live anywhere in the smallest space...
KJRR
KJ
Cleveland, OH
Professional Curmudgeon
Check your leaf springs. One may be cracked at the front mount. Mine sounded like a knock from around the bed area on my SCAB. Jack it up towards the rear until the tire is off the ground and you'll see the spring hanging down if it's broke. Won't see the crack otherwise.
Living The Dream
There is a TSB on the driver seat noise. I had it done to mine.
Basically, they clamp a piece of rubber on the seat frame with some hose clamps.
Let me see if I can find it...
TSB21-2236
TSB21-2236
Bet Ford put their tech's thru a 40 hour high tech course to teach them how to install a piece of rubber and clamp !!!
Living The Dream
Don't forget the mandatory sensitivity and compliance training.
Don't want to offend the unused heater hose.
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
Empty everything out of your truck. Make sure sun visors are secured. Make sure none of the seatbelts are twisted, then they rattle. Check rear seat and back, they rattle too when not latched in. Then drive it around. Could be something simple.
HeatXfer
Nor Cal
Retired Pipefitter & commercial HVACR Tech
Looks easy enough for a DIY. I've got a rattle from the rear that started about a month after installing new Eibachs, so I thought was a loose shock. It turns out the plastic bed rails had loosened.
