Front end noise
Burntchicken
Marko
Las vegas
2022 Ranger Xlt
Hello, first post, so I installed some fox 2.0’s about two weeks ago and put the stock wheels back on, everything was fine.
Then yesterday I put on my new wheels and tires, but as I did I noticed my both sway bar endlink boots were off so I loosed the nut to help to put it back on, tightened them back. Also torqued the axle nuts.
But after doing that I drove the truck then started getting some vibration then a clunking sound appeared when tires are moving and increase with speed.
It’s raining today so I will check everything when that stops, but would anyone know beforehand what the noise could be? Appreciate it.
Bob902
St. Louis
2021 Ranger XLT
RETIRED!!!!
Have you tried putting the original wheels back on to see if the vibration is still occurring?
Burntchicken
Marko
Las vegas
2022 Ranger Xlt
not yet, but the vibration was a 40-50mph then it just turned into a clunking noise immediately and got worse as I limped it home. Tires are balanced.
chrisakz
North Jersey
2019 Magnetic Supercab XLT FX4
I would recheck your lug nuts.. I’ve noticed with hub centric rims that it’s quite a snug fit to lay them flat on the face of the rotor
CO2Ranger
Did you get an alignment after the lift?
CO2Ranger
Didn’t tighten the lug nuts smh, double checked every wheel but that one, sorry yall
Glad it's an easy fix and you and the Ranger are still alive!
CB750F
Qc
Human
Not to worry, I've done my share ... ?
Dr_Strangelove
Adam
Henderson, NV
'22 XLT Supercrew 4x4
Art, Design, Photo & Video
Agreed. You were wise enough to park it until you figured out what was causing the issue. Glad you got it sorted the cheap way.
