How much free space needed - front suspension
UtahShooting
Utah & CA
2019 Ranger Lariat FX4
Real Estate
Got new tires (275/65 R18) installed on FX4 Lariat at same time I had Bilstein 5100's installed to lift front level. Stock rims.
They fit and look great with no rubbing so far during street driving.
I did notice that when I stuck my hand behind tire there is only 1/2" or so of space between front spindle and inside of tire. I'm thinking this shouldn't be an issue but want to check with folks more knowledgeable before I take it offroading.
machinist85
n/a
n/a
A 1/2" is more than enough. As the suspension flexes the distance between the tire and spindle stays the same.
UtahShooting
Utah & CA
Real Estate
That's what I thought but wanted to make sure. Thanks!!
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
Be careful if you air down. It should be the bottom that flexes the most but I just want to mention it.
Even woth an air down it will be fine. Never had the issue on my ranger and im pretty sure I had 285/70-17 woth no spacers on factory wheels.
wdeydwondrer
Louisiana
2019 XLT SCrew FX4
I just happened to check behind mine today after I put the new grabbers on last week and I can't put a finger between the tire and spindle, probably 1/2'' clearance. No rub marks or anything though so good enough I guess.
