Lablanca2019
- First Name
- Armando
- Joined
- Oct 1, 2025
- Threads
- 3
- Messages
- 39
- Reaction score
- 30
- Location
- Edinburg, Tx
- Vehicle(s)
- 2019 ranger stx
- Occupation
- fuel hauler
For some reason iam able to get dtc for the fcim but not live data as for the codes I was expecting the recycle door circuit since it's unplugged what would be explain the others or would the recycle fault trigger the others ?With that (Temp) - as a general guide - makes me think the Evap is actually getting cold and the next step - which Forscan does not have - is to view the - Temp Door Actuator (position) is it actually driving to (LO) and staying there.
But if the Evap is actually 33.8 Deg or Lower - then the PCM is commanding the compressor clutch to disengage - this is the protection cutoff temp to prevent evap freeze up.
Will it drive (LO) without selecting (Max Ac) ?
Are there any popping sounds - under the dash?
This truly needs a scanner that can see all the PIDs in the FCIM as well as the PCM for the Climate Control System.
Need to see:
The Door Position PIDs - Mode - Temp and Air Inlet
The Temp Sensor's PIDs - EVAP - Panel Discharge - Floor Discharge and Humidity / Temp as well as the Ambient Temp Sensor
Basically - you have 60 deg air from the Vents - We need to know what the actual temp sensors are reporting - as these are being reported to the FCIM
So yes - we need to shift focus to the control side in the climate box.
