Help me pick out rims !
NotBudule2
NotBudule2
21 Ranger
I'm not sure what your budget is but I always liked the Method wheels and was thinking about getting them on my '19 before the accident. Here's the ones they have for your '21 Ranger. Most of them have several different colors so there's plenty there to confuse you even more. lol
https://www.methodracewheels.com/collections/all
Since there is no new SuperCabs for me to purchase and blow my money on , this one is it ! NO BUDGET ! I WILL FILL MY 6 FOOT BED WITH PARTS AND ACCESSORIES!!! And maybe, just maybe, I will finally try a tailgate dam... ((dare i say it ???)) DAMPER!!!
veedubtuner
Morgan
Tulsa, OK
2023 CG XLT Scab FX4 Ranger/2004 VW R32
VW Parts slinger
Nomad
Maryland
2020 Ford Ranger Lariat
Robert,
I can sympathize with your situation as I was in the same boat as you at one point. The number of wheel and tire choices can make your head spin for sure.
I would say that to go with 17-inch rims over 18-inch rims (depending on your financial situation) is a solid move. A lot of guys (myself included) think they ride better than 18s (depending on what your ultimate goals with the truck are) because of the extra sidewall, and it definitely opens up more tire choices.
Honestly, a perfect option for you might be the Ford Ranger Tremor wheels (the 17x8 version, NOT the 17x8.5 Ford Performance version) . I actually went with them for my truck, and they hit every point you mentioned:
  • Size & Tires: They are 17-inch rims, which will give you that better ride and a ton more tire options to pick from.
  • Color & Cleaning: They come in a dark "Magnetic" gray that looks almost black and has a simple spoke design that's really easy to clean.
  • Weight Savings: They're also pretty lightweight for a factory wheel (around 25 lbs). Keeping that unsprung weight down is always a plus for handling and suspension response.
  • The Perfect "Poke": The offset is lower than stock, so they'll stick out a bit for a more aggressive look that will work perfectly with flares. The change in offset gives the truck a more planted and stable feel on the road. While a big offset change with aftermarket wheels can sometimes make steering feel heavy, the Tremor setup is what Ford's engineers designed for the truck, so the handling feels confident and correct. The offset is designed to give you clearance from the inner suspension and struts, which is where you can get into trouble with some aftermarket wheels. It pushes the wheel out for a bit more aggressive look, and while it's closer to the fender, it's a known quantity designed to work with larger tires, especially on a leveled truck.
  • No Balance or Fitment Guesswork: This is the biggest win. Since you're worried about balance and compatibility, you can't beat a factory wheel. Because it’s an OEM wheel, the fit is guaranteed. You don't have to worry if the offset change is "acceptable"—Ford literally designed this exact setup for the Ranger platform. It’s hub-centric, so no rings are needed, and your local shop will have zero problems getting them balanced perfectly.
Even if you don't go with these specific rims, hopefully I've given you some good metrics to consider in your search.
NOMAD
NotBudule2
NotBudule2
21 Ranger
Did you get your wheels yet, Robert?
No, I'm just starting the process and was pretty damn sure I wanted to stay with black...
Untill you posted that Pic, NOW , I'm not so sure as those look sweet af and kinda Ole skool to me , I was also wanting ole skool roll bar with the round lights ...
pickettf3nce
Troy
Arizona
IS Manager
Go for the 17's. They'll give you more tire options and a more comfortable ride both loaded and unloaded.
Food for thought; Black wheels are not easy to keep clean, especially if you live in a dusty or muddy environment. Every time the sun hits that gloss/semi-gloss paint you're going to see the dirt and brake dust caked on. Grey/Silver/Bronze will "look" much cleaner regardless of how clean you keep them.
For some additional context making your decision, here's a set of KO3 285/70r17s on some 17x8.5 -10 American Outlaw Lonestars. Just got these tires a couple weekends ago.
Going up from a 265/70 to a 285/70 tire with that low of an offset required a considerable amount of cutting on the front crash bars and the rears to be notched. Otherwise, I was rubbing at ~1 - 1.25 turns on my steering wheel.
New: 285/70r17s
Old: 265/70r17s
TxOTRRanger
Clay
Elwood, Texas
Just go big, right Clay @TxOTRRanger? ROADKILL! 😜
Dang right, Dave!
Go Big or Go Home.
Excellent picture of BIGFOOT I and reference btw.
Here is my truck with the Fuel Shok bronze 17x9 with the +20 offset.
Reality check.
My truck is...
On road 99% of the time
And off road 1% of the time.
After the ATs wear out. I'm going back to the Goodyear Wrangler Fortitude HTs that I was running on it when I first joined. They are good all season tires for the changing weather conditions.
Dr_Strangelove
Adam
Henderson, NV
'22 XLT Supercrew 4x4
Art, Design, Photo & Video
With a dark grey truck I think you could successfully pull off silver, bronze, or black - I agree that a graphite or an anthracite color could clash.
Bright silver wheels on a dark grey truck looks great in my opinion. The right bronze could be spectacular as well.. just depends on if you like that look.
CLASH!...😜
Grandaccess
Binghamton, N.Y
Computer Consultant
Roush :)
Dr_Strangelove
Adam
Henderson, NV
