Gibson Exhaust Systems
OKRaptor
OKRaptor
Scott
Oklahoma
2020 F-150 XLT, 2019 Acura RDX and a 2007 Mazda Miata w/turbo
Let’s hear the new exhaust!
It's not much louder than stock, I'm not going to video it because you won't be able to discern what it sounds like. I know I like it. Most likely would not because it would not increase the sound level enough.
StezenW
Stephen
Atlanta
I’ve got a Gibson dual and it is awesome! As other reviewer’s have stated it only opens up and gets loud when you want it to relative to your throttle input and which driving mode you are using.
Sport mode of course will give you sharp throttle response and rumble when you gun it and a nice long sustained sound when releasing the throttle whereas in regular drive it keeps the truck all very tame unless your foot heads south suddenly.
I had a local shop bolt it on and then spot weld all of the joints.
Chuck Lau
Chuck
Ohio
2020 Ford Ranger...2005 Mustang Steeda
Looks Great! I just purchased the Gibson 69550 Duals like yours. I can't wait to get them installed.....Was the Install Difficult? Love split Duals.....How is the Sound? I really don't expect much being a 2.3 Turbo....It sure will make it look Good! Thanks for the Pics....
StezenW
Stephen
Atlanta
Sound is great especially at idle when it’s warmed up. I really love it at all points in the rev range tho!
I had an exhaust shop install mine purely so they could spot weld all the joints as well as use the provided clamps just so there’s no way them pipes are coming loose! But you can definitely do it in the driveway with some patience.
Had mine on for 6 months now still going strong!
Fawnbuster
Indiana
Retired 34 years as LEO
CreedB
United States
2020 Ford Ranger XLT Sport
I just installed the Gibson dual exit exhaust system on my 2020 ford ranger. I am extremely happy with it. It sounds really good and gives it a but of a bass tone at idle. it was extremely easy to install, the only "problem" I had was taking out the old exhaust but I got it out and the new on tin in a bout an hour to 2 hours.
Fawnbuster
Indiana
I just ordered the single exhaust with the black.tip. I like the duals look but I have just installed rear lights where the tail pipes would be and my brackets only work on the oem bolt in that spot. Thanks for the post!
Rinn69
N. Central Iowa
Retired USAF MSgt
@CreedB Since you just installed yours, how much clearance between the axle and the exhaust ? I'll be lowering mine and hopefully installing this exhaust if it will still fit.
Thanks !!
CreedB
United States
Thanks !!
It should still fit. it has pretty much the same clearance as the stock exhaust.
Tim H.
TJ
Maryland
REALTOR
Looks great! For some reason the clip doesn’t play on my iPad. Where did you purchase from & what did it cost? Thanks
CreedB
United States
I ordered it from Throtl.com and it was about $630 after shipping and taxes.
Chuck Lau
Chuck
Ohio
check out amazon $594.00 Black Tips or $584.00 Polished tips....FREE Shipping Too.
Tim H.
TJ
Maryland
REALTOR
I’ve been comparing this system with the same version from MBRP. Very closely priced but Gibson is stainless steel muffler & tailpipes where MBRP is a combo of steel with aluminized tailpipes. Gibson seems to be the better exhaust for longevity.
Fawnbuster
Indiana
Love mine! No rattles or leaks.
