Gears disappear
jpboats
2019 Ford Ranger Lariat , Blue
why do the gear numbers disappear in sport mode?
t4thfavor
Chance
They reappear only when you're in "Manual" mode. I don't know why specifically they are gone in sport mode, but if you tap the + or - the gear indicator will reappear. It will then require you to manually shift until you exit S mode, or hold the + for a few seconds.
Hope that helped at least a little.
CoastieN70
Travelers Rest, SC
2019 Ranger Lariet
I believe he meant the vertical display on the right screen 1 bottom, 10 top that pops up when you press the manual shift button (+/-) while in the "D" mode.
In the Sport mode (S) the gear currently displays in red on the left screen and the rt screen numbers display is no longer active.
Also, if you have the gear pattern in the rt screen and push the +/- button on the shifter, the display will disappear.
chasvs
Tampa
The purpose of the Gear Display in D is so you can restrict how high it can shift. Press + or - to display the gear list and then press - and the highest gear will be reduced by 1 each time you press - . You can increase the highest gear as needed back to 10.
CoastieN70
Travelers Rest, SC
2019 Ranger Lariet
Wow! I did not know this, I must "play" tomorrow... :)
Deleted member 1634
Has anyone figured out why the gear indication column goes away sometimes, but stays other times? I don't need to press the + every time I go into drive for it to show up, including after shut down and restart. Sometimes it "remembers" my past "setting" and just shows it to me automatically next time I drive away. Other times it resets back to hiding the gear indications and I need to hit the + again to show me. And to make it even more confusing it seems like it only hides it the times when I'm watching for it to come up. haha
Ranger8729
Ashley
South Carolina
1987 Ranger & 2019 Ranger
I have found if my stop is less that 10 mins, it will "remember" that i want the gear indicator active when I restart. After that it defaults back to being off.
Mine always seems to disappear no matter how long/short it is when I turn it off. I'm so use to hitting the + now it's just part of my routine, hit the +.turn off traction control, turn on radio and press mirror button. lol
Deleted member 1634
Interesting. I'm pretty sure mine will automatically come back after stops longer than 10mins. Sometimes days later it seems, but certainly after hours of sitting.
So no real consensus on this yet then it seems. haha
mgallo13
Matt
Neptune City, NJ
2015 MM Focus ST (sold), 2020 MM Ford Ranger XLT
Financial Controller
I have a 2016 F150 XL 2.7TT super crew for work with the old 6spd, and the gear indicator (1-2-3-4-5-6) displays the same way- press plus or minus on the column shifter and it shows up. However, on my 2020 ranger they disappear after putting it in park. Pretty annoying, but certainly not the end of the world. Just wish there was a way to get it to stay.
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
On my Lariat they show up in the tach display as numbers when I am in S. It's disorienting.
Yes if you're in S and hit the + button the gears and tach will show up in the left cluster. But if you put it in S and don't hit the + they won't show up. In D the show up on the right cluster if you press the + but mine disappears every time I exit the truck and get back in. Damn this is confusing. lol
Racket
Here and There
Transient
I would totally want Ford/FORSCAN to make the right hand side display of the gears always display.
I could even see some curve the indicator and subtle animation a bonus.
I really don't understand why they didn't have them permanently on the gauge cluster? :crazy: At least have the option to turn them on/off in the setting like some of the other features.
Mobius97
Seattle
Ranger Lariat Fx4-Lotus Evora-Lotus Elise-BMW X7 M
I turned these on for the first time last week for fun. to see what the trans was doing. I couldn't for the life of me figure out how to turn them off during my 3hr trip. Now ever since doing that.....the gear numbers (in right screen) come and go randomly. I can drive for 15 mintue to the store...nothing. Next day same trip they are there. Go figure.
