Fun times dissecting a radiator
As some of you are aware, I recently replaced the Radiator in my 2012 Frontier. Well I have no intention of putting the old one back in and instead will replace the current one with a new OEM Radiator.
Well because of all that I decided to go ahead and do a teardown of the OEM Radiator I took out! To say the least what I found was interesting. If possible I would actually want @P. A. Schilke to chime in and give his input for the overall design and how it may compare to what he has seen with his days with Ford!
First we have the Radiator. As to no surprise it was a bit dirty in general. It's also 13-14 years old. For a Plastic Aluminum Radiator, it's a good idea to replace it before it cracks
Now is the time I got curious. I decided to go ahead and loosen the crimps and remove the side tanks. I started with the top to get a good look at the Radiator Core. What I found were some nice looking tubes! Many try to claim that the OEM Radiator for the VQ40DE is a 1 Row, but in reality this would be classified as a 2 Row(this is incorrect as it is just a 1 row. The cent piece is a strut to help with strength against vibration and twisting). That is determined by how many rows of tubes you have from front to back. In this case we have 2 Rows of tubes hence the 2 Row Radiator. I also decided to measure the tubes. From the outer edge of the tube I measured 1 3/8(in Millimeters it is 35 mm. Figured this would help some). The center divider is about 1/16. That makes the tubes fairly effective at 1 5/16 - 1 3/8. I also counted the Rows of tubes from left to right and found 76 total Rows. With some basic math I was able to determine that there is roughly 5,065.25 square inches of surface area for the Tubes to allow for cooling. That's quite a bit when you think about it.
Next I decided to open the bottom of the Radiator since that is where the Transmission Fluid Cooler/Warmer is located for this Vehicle (and many others). Now I did this because I wanted to get a closer look at the Cooler and see how it is designed. I originally thought it was simply a closed end pipe. Well to say the least I was wrong! If anything it is more like two things wall pipes fairly close in diameter(one being a bit smaller) and sealed to each other. The center of the cooler is completely hollow and allows coolant to go right through. For what it's worth I actually like it as it should be more effective for heat transfer having coolant on both sides of the cooler/warmer.
Now once I get my new OEM Radiator, I will be taking the KOYO apart and comparing. Something tells me that it will not be the same and I suspect I will see reasoning why it isn't as efficient as the OEM.
EDIT: so the total thickness of the OEM Radiator is 35 mm for this particular vehicle. Also I found out that the center piece in the tubes is called a strut support for the tubes. This simply helps the radiator with bending and twisting and vibration when the vehicle is operated. A bit important when you think about it.
For 2012 looks REAL clean!
That it does, then again it only had about 150,000 miles on it. Also the transmission cooler looked like it was showing signs of leakage on the inlet/outlet ports.
k1w1t1m
Tim
Bull Shoals, AR
2021 Ford Ranger XLT FX4 SCREW
I wasn't expecting the transmission cooler to look like that. I suspect those end seals are the weak points that give Nissan a bad rap for failure.
What if I told you that this is the most up to date Radiator from Nissan that does not have that issue? Earlier designs certainly had the issue, but not this one.
Well I finally got my OEM radiator installed today as it just came in today. To say the least I probably got it done in record time. Killing system is already bled and from what I can tell it's running a lot more efficient than it was with the previous KOYO.
With that said I decided to go ahead and take apart the aftermarket radiator and to say the least I am very disappointed with it............ There was only one thing I did kind of like about it and that was the transmission cooler. Even then I still wasn't much of a fan.
For reference here is the bottom end of the aftermarket radiator. I decided to go ahead and take a measurement of the tubes and each tube measured at 9/16. Combined that is only an 1 1/8. Compared to the factory I lose 1/4 per tube section of heat dissipation ability. To some that does not sound like much. But when you do the math that is a lot of surface area you take away. To give an idea the exact surface area available on the aftermarket radiator is 4,266 square inches...... That is 800 square inches less than OEM for heat transfer!!!!!
Here is a closer look at the transmission cooler. From what I can tell it is a bit bigger in diameter and it is brass instead of aluminum. I feel Nissan probably could have gone with this design over the other, but to say the least I definitely prefer the factory.
What's my take from all this? To put simple the factory is definitely better when it comes to a factory type replacement radiator. I'm sure when it comes to your aftermarket performance radiators that are all aluminum, chances are things are going to be a bit different and probably be a little bit better. Hopefully everyone else here takes good note of this for the future!!
Also if @P. A. Schilke could please join the chat and giv some insight, that would be awesome!
Hi Chris,
Welcome to the world of aftermarket parts...It is buyer beware. Buy from a car dealer will likely result in a good fitting and functional part that meets OEM specs including performance specs too...but not always, unfortunately. Trusted names in the aftermarket industry will also likely land you in good company. China parts...um..maybe fit okay but likely have not been tested like OEM unless they also sell to the OEMs...If you shop by price alone...you may get poor performance.
Lets take Engine Mounts. Two pieces of metal sandwiching rubber. Most do not know but mounts can be tuned to minimizing powertrain vibrations. Some aftermarket parts just use rubber of the correct thickness and durometer, but they are not tuned...ie no eye of Newt in the rubber mix. So you install and all of a sudden you have new noises, vibrations etc.
best,
Ford Motor Light Truck Engineering
Hi Chris,
best,
You are certainly not wrong with Aftermarket Parts not always being what they claim to be. Many out there including myself have had to learn the hard way on this one.
One thing I am curious about during your time at Ford is if you had the experience to check out lovely Aftermarket Parts and compare them to the OEM like what I did above?! If so what other experiences can you share? The Motor Mount is a new one to me, but it makes sense.
Hi Chris,
It is hard enough to keep OEM parts on track with design changes, but I have had a few times when I was involved in litigation against Ford Truck that Ford found may have been caused by an aftermarket part. I do not want to refer to the specific litigation, but in the test lab, for example, we tested the OEM parts and aftermarket parts and it showed aftermarket parts failed way before OEM parts. Lawyers then took the data in most cases, converted it into legal speak and headed away and we were never advised if it helped or not...
best,
Stevedbvik1
2022 Ranger Tremor XLT
Hi Chris,
best,
The lawyers didn’t get back to you because they wouldn’t be able to bill their time to you ?
Cmar
Cam
Australia
Ford Ranger PX
Medical Scientist
Yes that's certainly true, over here with our generally hot climate there is this belief among some that with radiators, thicker is always better.
Not so, after a local aftermarket radiator company - one that was criticized by many because they didn't offer Land cruiser radiators with a gazillion cores, did testing that demonstrated past a certain number of cores, it's a process of diminishing returns with the increased air resistance and the fact that the air reaching the rearmost cores was already hot, reducing the potential gains.
Their analysis also showed that factory cores do an OK job most of the time, and one extra row was more than enough in most cases.
You wouldn't happen to have more information on that would you? To specify is there like some kind of article going over the tests that were done? If so it would be excellent to share here since it's good information.
Cmar
Cam
Australia
Ford Ranger PX
Medical Scientist
It was a long time ago I saw it but I'll have a dig for you!
That's fine. I'm in no rush,but I am curious
