Front blinker bulb to LED replacement
joeb427
Any front blinker LED replacement out there that is a simple plug and play?
Caluke
Lucas
Automotive tech
No. They will all require a resistor or BCM modification using FORScan software. I am running some switchback LEDs in my truck and I love them. I used FORScan to program the BCM.
Deleted member 1634
I swapped mine out to LEDs as well. Tried them out before I installed the resistors. They hyperblink inside the cab, but the lights themselves still blink at the normal speed. So it all depends if you care about hearing the quick tone or not. The LED turns and matching resistors from Diode Dynamics (where I got mine) was worth it for me.
Psykostevo
Queen Creek, AZ
the ones I installed hyperblink too. I’m going to get forscan to disable it.
bdunk
Brett
Fort Lauderdale
Firefighter Paramedic
What was the wire colors for the wires you connected the resisters to? I installed the Diode Dynamics resisters but either I connected to the wrong wire, are the connection is bad because its still hyper blinking.
Deleted member 1634
Well, the sun is yellow, it heats the ground, that's how they name stuff. haha
But seriously, yellow and green is what I connected. The brown is the running light wire, and I think yellow is turn, and green is ground. Took me a couple tries as well. haha
seanellaz
Sean
Tucson, AZ
Healthcare
Just be aware that - If you have the Halogen Light assemblies, that bulb is Park & Turn, if you have the LED assemblies the bulb is (Turn-Only)
I have the LED assemblies, and I use these - Great & Bright and ZERO issues since Install 3.5 years ago - these are turn only
Joe hasn't been on here in 3 years and also sold his Ranger and bought a Ridgeline along with his brother Tom @SubVet. lol
BTW I'm using these and they're cheaper. 😜
https://www.amazon.com/OXILAM-Yello...70697&sprefix=Oxilam+7440,aps,398&sr=8-1&th=1
LB'sTremor
Loren
Tampa
22 Iconic Lariat Tremor
IT
