Ford Performance diff cover
MarcS
Marc
M
No drain plug? Has anyone been able to drill and tap for a drain plug? Guessing there should be no warranty issues if I install it. Cast iron should be easy to drill and tap…but is there room between the fins? Im only looking at pictures…
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
Pretty sure it's underneath the Ford Performance label and pointing straight up.
Summit Racing's description says it has a drain plug.
https://www.summitracing.com/parts/fms-m-4033-r?seid=srese2
There are two fill plugs, normally you will use the lower one. The upper one is for use if your truck is lifted and the axle is rotated upward.
MarcS
Marc
M
2022. Sorry mistake
MarcS
Marc
M
Its a 2022 NO drain plug! Maybe someone has one and can answer?
MarcS
Marc
M
There seems to be 2 of these Ford Performance covers:
m-4033-R for Rangers
m-4033-BR for Broncos (the pic SHOWS a drain plug!)
Whats the difference? I thought the axels were the same?
As long as you have the Dana M220 it should fit. The M220 is on all the 4x4 Trucks. I don't know if the 2WD trucks have them
MarcS
Marc
M
Looked on Levittown website its says the M-4033-BR (with drain plug) as NOT fitting Ranger…only Bronco….
MarcS
Marc
M
Hope Benny from Levittown can answer WHY the M-4033-BR won’t fit Ranger.
It DOES have a drain plug!
