Ford Leveling Kit
AJSimmon
Chesaning, Michigan
2019 Ranger Sport 4WD Silver Crew
I am considering purchasing the Ford Leveling Kit and I am having a hard time justifying the cost. Has anyone had the Ford kit installed? If so, what size tires are you running? Is it worth the money? Thank you.
Formula Indy
Phillip
Carmel, IN
I asked my service advisor at my dealer about it and he told me they didn't do it and referred me to a local 4x4 shop.
gfitzge2
Gregg
Louisville, Kentucky
Retired Electrician
Search the forum there has been much discussion on this subject here is an example:
https://www.ranger5g.com/forum/threads/front-leveling-kit-best-bang-for-buck.7328/
To answer your question I am happy with mine along with the BFG KO LT265/70R 17
One thing to think about If you use a dealer or certified installer (see FPP warrantee) you should have less problems with Ford if you have any warrantee issues. That is worth some value in my opinion.
Dochatley
Jerry
Dallas
I bought the Rough Country level kit and had my Ford Dealer Install. Kit was about $100 and installation was about $150. Then alignment was $125 (ouch). But worth the insurance of them installing if something goes wrong.
AJSimmon
Chesaning, Michigan
Did you swap out the crash bars?
njdriver19
nj
19 ranger lariet
I have the kit installed, had it done at my friends shop not the stealership, Was it worth it ? In my opinion yes, ride is stiffer and all round better, truck looks
gfitzge2
Gregg
Retired Electrician
njdriver19
nj
19 ranger lariet
Remember to level your headlight after , the cut off on my leds lights was very high after
The big thing to consider with this kit is what are you planning to do with the truck? I wont argue that the Fox kit is nice but if you are doing heavy off road or heavy towing a lot then I would recommend something else. If you are doing light off road and daily driving with some towing here and there then you should be fine. Will it be more comfortable compared to stock? Absolutely and that by itself will more than justify the cost.
Chris M
Surprise, AZ
2021 Ranger XLT Sport 4X4
Security Supervisor
I had it done by Ford and am quite satisfied.
2019 XLT Sport 2WD.
Still have factory wheels and original tires. No issues with that part whatsoever.
Ride is awesome compared to from the factory.
Make sure whoever does your leveling also adjusts your headlights to the proper safe settings! (You MUST apparently be specific about this, otherwise the tech may just point them at the ground like mine were done this weekend).
Happy Motoring! :)
LiftMyRide
George
Denver colorado
2021 Ford Ranger XLT
Assistant Manager
wow the dealer charged you next to nothing on that install! they are quoting me $242 an hour not including parts or allignment.
i want to go 285 70 617
SilverSlugger
Wally
AZ
2019 Ford Ranger Lariat FX4
Baking
Do you have stock wheels? If so that 285 width may give you some problems without adding spacers.
For reference, I have the Fox 2.0 and just put on 275 65 18's and they are very close to the spindle on the back side of the tire.
LiftMyRide
George
Denver colorado
Assistant Manager
i have stock rims but 285's were a thought. i just thought sinse your rim was an inch bigger than mine i could go a little bigger but i ned to look into it farther
NOVA_Ranger
Northern Virgnia
Bought a Rough Country kit for my truck in May 2019. Had a buddy's shop toss it on and it wasn't too much. Four years, lots of off-road use, and about 60k miles later I've had no issues. One thing to consider is replacing the factory nuts, if new ones are not provided. Trying to reuse the originals will lead to them coming loose, which is VERY bad. These leveling kits are all accomplishing the same thing and they're equal in my book, as long as the overall quality is good.
NOVA_Ranger
Northern Virgnia
Sad. Leveling kit instructions include procedures for aligning both the cruise control radar and headlamps.
I pushed my dealer to make sure they completed these. Reply was, "We've never done these before and have never had a problem". :facepalm:
Never had to adjust them on my truck. I might have dialed the headlights down a hair myself, just to be extra kind to others, but I can't remember. ACC and everything is fine, considering the fairly minute change.
