FIX YOUR MUSHY BRAKES
teookie
2022 Tremor
I literally used this yesterday when I bled the brakes. It was almost identical to what came out other than the stuff coming out was a little darker. Same thickness and everything. Also this is what autozones website says is for the 2019+ Ranger so there’s also that.
How did your brakes feel after bleeding? Did you see any bubbles come out? Have you done the ABS bleed with FORSCAN? How much of the OEM fluid did you bleed out?
I bleeded about 1/4 cup from each brake, didn't see any bubbles, and brake feel did not improve. I will try the ABS bleed with FORSCAN in a few days when my adapter gets here.
t4thfavor
Chance
I did the abs bleed earlier in the week without opening the bleeders. I did see very micro sized bubbles dissolved in the fluid and possibly a bigger bubble (which could have been in the bleeder line). The brakes improved, but not to the level I expected. I took maybe half a cup out overall.
teookie
2022 Tremor
I just did the FORSCAN ABS brake service.
I pressurized the brake system to 20 psi and opened the blead screws when prompted.
I did the front axle first as directed by forscan. (this is strange, but whatever)
Ran the front axle FORSCAN service and the ABS pushed out enough fluid to drop the reservoir from MAX to just below MIN.
I topped off the reservoir with fresh fluid.
Then I ran the rear axle. ABS pushed out from MAX to MIN again.
I topped of the reservoir.
Service complete. I did not get any warning lights on my dash.
Driving impressions: Brakes feel firmer. Not as much as I was expecting based on other testimonials in this thread, and nowhere near as firm as brakes in my Focus ST, but there is noticeable improvement. So far I've only driven around the block, so I'll add more impressions if warranted after a longer drive.
Steven D Tipton
Ohio
2019 Ranger STX Supercew & Ranger XLT SuperCrew
How much Fluid did you push through the system in Qts? I'm asking, Because I kind of understand what you did but doesn't seem like the procedure I recommended.
I recommend, ABS is bleed, air out of module. So don't do that again. Start at Pass Rear, Driver Rear, Pass Front and finally Drivers Front and only do a regular bleed now. Use a clear tube and some kind of bottle filled with brake fluid enough to submerge the end of the hose in bottle and of course other end to bleeder. Foot pump brake pedal, till you get a clear flow through tube( no Bubbles). Do each wheel that way. Me personally, What you listed you did, if I'm understanding correctly. You circulated the air from module into main lines but didn't flush enough through the main system. I run a good amount of fluid, I split a quart between all 4 wheels. That's me. Then I know it completed right.
teookie
2022 Tremor
I flushed a whole quart through. It's possible there are still bubbles in the lines somewhere, but I kinda doubt it. I did a regular bleed like you described last week before I got the FORSCAN usb cable thingy. It is curious that FORSCAN asks you to do the front axle first - I wonder why that is.
Ok I did the foreskin ABS bleed procedure probably six months ago. Yes it helped but slowly my brakes kind of went back to being wish again. Yesterday, after waiting for the proper brake fluid to finally come in, I got under there and actually bleed the brakes. Guys I probably get 60 bubbles or more out of this brake system total and now they are finally feeling like they should !!!
Is this a two-person job? 60 bubbles total or each wheel?
AdamHarris
Adam
Blue Oval City, TN
Collision Repair Instructor
Yes having a second person to manipulate the brake pedal is a must. 60 bubbles total (roughly 15 per wheel, was pretty even among all 4 wheels it seemed).
AdamHarris
Adam
Blue Oval City, TN
I literally have no idea what you are talking about. Forscan did not ask me to pressurize anything or open any bleed screws or begin with the front axle. It just did its thing very loudly, 2 rounds of loud. Months later I did the manual system bleed procedure where someone is on the brake pedal while you are under the truck starting at the most distant caliper with your bottle of clean fluid and a 3/8s hose etc. Did you use a tool or machine to "pressurize the system to 20 psi" or what?
t4thfavor
Chance
Because the process was written by engineers, and not mechanics...
Porpoise Hork
Bret
Houston
IT
You can also adjust the pedal engagement height a fair bit by adjusting the threaded brake pedal rod under the dash. Only takes a couple minutes with a wrench and pair of pliers. I did this on mine before the ABS bleed procedure was discovered. After doing both the brake pedal feel is nearly identical to that in the F150's. That with a high engagement point about equal to the gas pedal and very firm pedal. Last time I took it in to the dealer for service they commented that mine had the best feeling brakes of any ranger they had driven.
If you decide to adjust the rod length, be extremely careful as it will cause the brakes to drag if you go too far. Drive it around town for a good 20 or so minutes to get the brakes good and hot then take a baseline temp reading of the rotors and calipers with an infrared temp meter. Make smaller adjustments to the rod increasing the length, test the pedal feel and then test drive again for 20+ minutes and recheck temps. Repeat until the pedal engagement point is where you want it and no change in rotor/caliper temps are observed. At any point if you see an increase in temps back off on the rod length a couple threads and lock it down.
Steven D Tipton
Ohio
Doing the ABS bleed after the regular bleed is pointless unless you redo bleed normal lines. The point of abs bleed is to push air out of module. Air goes into your lines and you bleed air out of the system.. I have done 6 of these now. Not pointless at all. Just needs to be done correctly.
MIBuckeye
Grass Lake, MI
2021 Ranger Lariat Tremor
Ok... did this month's ago and now it appears to be soft again...forscan won't display the procedure. My license good til 8/22....what am I missing?
AdamHarris
Adam
Blue Oval City, TN
I mean..did you read through the thread? Several of is went mushy again after doing Only the forscan bleed. You have to do a traditional bleed as well, AFTER the forscan bleed. Don’t know what “wont display the procedure” means.
MIBuckeye
Grass Lake, MI
WTF. Yes, I read the thread. Did you read my question? It had nothing to do with a physical bleed. It was that Forscan isn't displaying the procedure. Looking for some assistance. Not shitty childish responses. Just don't reply for God's sake particularly of you don't even understand the question.
t4thfavor
Chance
When you load Forscan, don't load a profile, create a new one and do the scan again. Sometimes the saved profiles "forget" about modules. I'd do a physical bleed though, in addition to the ABS procedure. I was too chicken to do them both at the same time, but I did the ABS one and a few days later I did a physical bleed (of about 1 reservoir of fluid) with the help of my 9 year old son. It definitely helped, but did not make the brakes feel as good as my other vehicles (which are nothing special).
