FIX YOUR MUSHY BRAKES
Eoj
Albuquerque
21 lariat fx4
I can’t use my old elm327. No switch. So deleted my profile and should have a new adapter Tuesday. When I get in one of our acuras the first couple stops I make about throws everyone through the windshield. I don’t drive them much and really don’t like them.
Hellrazor
Clement
Richmond
2021 ranger
Baller
Do you think you can simulate the same thing by driving in the snow? Maybe drive 50mph push brake and let abs kick in. Do it like 5 times in a row.
fusseli
EE
that wouldn’t be anything like a bleeding procedure. Sounds like the abs controller can bleed itself. Which is different.
kskr
Kansas
2022 Ranger Lariat
Sorry, no. I decided to take matters into my own hands, read control... Bought the software and connector and completed the "Mush Brake Fix" that yes, makes a hell of a racket. Problem solved. I was about to head on a 4k adventure and had no time to get to my dealer 3 hours away. Would be interesting to know if that works too.
Thank you.
fusseli
EE
2019 FX4 with 30k miles, doing the procedure this morning. I'm hopeful!
paval3
Val
Pennsylvania
I have a quick question.... I did the fix for the mushy brakes, that's the only thing I did with Forescan. Question is, if/when I have to get a new battery... will that wipe out the Forescan fix? I know with my Mountaineer, when the battery is disconnected sometimes I have to do some resets... but maybe it depends on the length of time battery is disconnected??
Silver
Steven
Mora, NM
21 Ranger Tremor, 73 Bronco
Retired Navy Officer
Don't think so, since the operation is not a "setting" but a physical "procedure" conducted by the system. Basically my thinking says, the procedure will not go backward, just like bleeding a standard brake system - can't un-bleed the hydraulic system.
paval3
Val
Pennsylvania
Thank you! I was hoping to hear that.
fusseli
EE
Did the abs self bleed as described. Could maybe notice a small difference but nothing huge. So I guess my 2019 wasn’t too bad as it was.
Steven D Tipton
Ohio
2019 Ranger STX Supercew & Ranger XLT SuperCrew
This video is 100% correct but you have to bleed main lines out after bleeding air out of ABS module. Yes, I heard you had 20 years and respect that but Abs air gets pushed out of abs module in to main lines into small bubbles. Over time, these tiny bubbles will joined back together in to one big bubble. Same issues will return. You 100% right on the fix but you have removed the air remove from the abs module to main line. Now you have to finish bleeding air out main lines afterwards. I have done this in my shop and problem is gone for good. Nice video
Also very important : DOT 4 Low Viscosity (LV) High Performance Brake Fluid or equivalent meeting WSS-M6C65-A2. Make sure you use LV
treimche
Troy
FORT MYERS, FL
2019 Ranger SOLD. 2005 S2000
Accountant
I did the FORSCAN bleed procedure on my 2019 Ranger Lariat this fall after seeing this information posted and it made a huge difference for me. Big thanks to Trevor @2Xero21 !!
Hellrazor
Clement
Richmond
2021 ranger
Baller
What’s the main lines? The four bleeder on the calipers? I was thinking about bleeding my brakes because I did the service bleed and it did fix my pedal. I was just wondering where all the air went?
Steven D Tipton
Ohio
Brake fluid travels from master cylinder to abs module, abs module to each wheel. Yes calipers, need bleed to removes air that's been pushed out to lines in between calipers. System doesn't bleed air out into thin air. Unless you crack the bleeders. My way of bleeding, is a Gatorade bottle with 1/4 brake in it. Clear hose from bleeders into bottle of 1/4 brake fluid. Pump brake till you get solid stream of fluid no bubbles
Dgc333
21 Ranger Lariat
Considering that there have been about 200 people that have reported doing this routine in the thread, having great success and not reporting it degrading over time, I would say it's permanent. I did it at the end of August last year and the brakes have been consistently good since.
I don't think it has anything to do with air in the system. I would guess one or more of the return valves in the ABS module is leaking allowing fluid to pass to the accumulator resulting in the soft pedal and slow fall of the pedal to the floor. Running this routine cycles the valves in the ABS rapidly effectively "breaking them in" so afterward in non anti-lock braking the return valves don't leak giving you normal brake feel.
FYI, Whether you have many tiny bubbles or one large bubble in the system it won't change the mushiness. The overall compression of the air in the system whether spread over many small bubbles or one large will be the same.
