Extended Heavy duty wheel studs?
McLeadslinger
Trevor
Pikeville NC
Aircraft Electrician
Looking to install heavy duty extended wheel studs and open end lug nuts for the trail.
who makes them or are ARP’sthe go to?
NvrFinished
Shea
SoCal
2020 XLT 4x4 Rapid Red
ARP makes studs that typically are stronger than O.E. studs. You can also order them longer. However, you can't really go with HD studs since they would need to be a larger diameter.
Ds_2020Ranger
2020 Ranger XL FX4
The Ranger and the Bronco share the same wheel stud, so its possible ARP may come out with a set for the Bronco, but I ordered a stud from my local dealer to measure knurl etc to see if I can find something in the ARP catalog that will work.
McLeadslinger
McLeadslinger
Trevor
Pikeville NC
Not necessarily larger diameter but made with stronger material.
Ds_2020Ranger
2020 Ranger XL FX4
Ordered an OEM stud from ford, got it today and measured the knurl and sent the measurements to ARP. They told me if I provide the measurements they will let me know if they have anything that will work.
McLeadslinger
McLeadslinger
Trevor
Pikeville NC
Awesome!
Ds_2020Ranger
2020 Ranger XL FX4
I measured the knurl at .505 and found a set of moser studs-
Wheel Studs, Press-In, 12mm x 1.5 x 2 1/2 in.
Right Hand Thread, .505 in. Knurl, Set of 10
Not overly expensive so I ordered some from summit to look at and compare to the stock stud.
Just in case ARP doesnt have anything.
Ill update again when I have more info.
Ds_2020Ranger
2020 Ranger XL FX4
Here is what I got from ARP-
Hi Dylin,
Please find attached kits I found that may work.
The knurling is the same at .509” just the UHL will vary and the choice of a bullet nose at the end or not.
If your hub/axle holes are cast iron make sure that they are within .493-.503”diameter.
Best regards,
Sean Lipsett
Technical Support
Automotive Racing Products, Inc.
800-826-3045
ARP-bolts.com
Additional Information
______________________
Part Listing
ARP-100-7726 - Part #: WSAU2.000-1G - Qty/kit: 5
( subaru wrx/brx & scion m12 x 1 )
Part Listing
ARP-100-7725 - Part #: WSAU2.500-1G - Qty/kit: 5
( gm late model m10 x 1.5 ws )
Part Listing
ARP-100-7708 - Part #: WSAU.509-1 - Qty/kit: 5
( m12 x 1.5 late model gm )
Part Listing
ARP-100-7713 - Part #: WSAU3.250-1 - Qty/kit: 5
( late model gm wheel stud )
Looks like I will need to order a hub assembly to do some testing.
Ds_2020Ranger
2020 Ranger XL FX4
Ordered a set of front hub/bearing assemblies from Levittown, should arrive next week so I can pop the oem studs out and measure the holes.
Got the Moser studs today, below is a pic of the Moser stud next to the oem stud-
McLeadslinger
McLeadslinger
Trevor
Pikeville NC
That’s awesome. I’m gonna order some as well. I’d really like to find studs with the bull nose end in them but the extended studs make it so much easier to mount wheels, especially in the trail.
Ds_2020Ranger
2020 Ranger XL FX4
Alrighty, finally got around to getting something done. Got the extended studs in. I wanted to press them in, but I ended up just using my impact gun and a stud install spacer-
Ill probably put these hubs in when I upgrade the front suspension next month. Stay tuned.
TruckBox
Indiana
2022 XLT
Hired Nerd
Those Moser studs look beefy... they're also made down the road from me. Good people. Always fun seeing the off small business on the internet.
