NvrFinished
Something to remember is that tire manufacturers have long ago switched to the letter rating system for load ratings on LT radial truck tires. The reason is that most load range D and E rated tires do not have 8 and 10 plies like the bias ply tires from many years past. Most today are only 3 ply with maybe an extra nylon cap under the tread. The additional weight is usually due to more rubber from an extra 2/32's of tread depth, a thicker steel bead, and more rubber that wraps around the bead area. This is one of the reasons the sidewall area does not flex quite as well when aired down.
