DIY: Adding the 12V Power Outlet Option in the Bed
McDeuce
2021 Ranger Lariat Tremor
Couple of updates since I don't post here often...
I've got adapter plates that fit the standard 1"x1.25" MOLLE PANEL holes available later this week (see pic). This way you have direct access to the plug/socket since most of the panel systems kinda cover the hole.
ALSO, I will have pre-made 8mm DC cables available. E.G. what you use to charge your Goal Zero Yeti, Jackery, or other battery bank system that uses that standard connector. Those along with pics will be added to the store later this week as well.
And FINALY, I have a bunch of the FEMALE connector kits available. This is the OEM side connector that's mounted to the frame of the truck. So if you want to do your own direct battery wiring, you can get that connector, some wire and a fuse, and DIY it to my current kit.
Wow! Awesome ! So will this fit in a Builtright Molle panel? What do you do with the hole in the bed ?
WLFPIR8
Ethan
Central Ohio
whor.us
2019 Ranger Lariat FX4/Sport in Saber Orange
Systems engineer by day, maker and multimedia guru by night.
The wiring still goes through the hole in the bed, and just mounts on the molle panel right in front of it. I did order one of the molle panel sets, so I'll have a better write up on the site for install, but it all works the same way, just another hole. I AM supplying some "sleeving" with each one that can go over the cable where it rests on the hole, just in case there might be enough movement to eventually break down the insulation.
McDeuce
Very good ! We used to use these plugs from Capco https://www.caplugs.com/round-tubing-plugs-ccf .. we would punch a hole in it if we could route the wires through it or make a slice from the middle out to seal holes in a fire wall.
McDeuce
Since I have your aux wire harness I could install 2 in the panel. Awesome !
WLFPIR8
Ethan
Central Ohio
whor.us
actually, there are those holes lower down that have factory gromets in them, I wonder if those would work, I need to test that. The upper hole is just a weird size.
LOL, I don't even have the truck but I did just receive the Wolf Haus power thingie (the one with 12V and pigtail plus adapter).
And not only did he send it right away, but it's so nicely made. Even my wife commented on how well it's put together! And the instructions are impressive!
Thank you Ethan!
McDeuce
Some of the lower holes are used by BuiltRight to mount their Molle panel
WLFPIR8
Ethan
Central Ohio
whor.us
Ah, yeah.... I just got my panels too. prolly get those installed this week.
McDeuce
Nice ! I saw a YouTube video that said BuiltRight is coming out with a panel for the front wall of the bed later this year. Very cool!
WLFPIR8
Ethan
Central Ohio
whor.us
Just got the panel set in the mail today. Finally able to do a test fit on the actual thing and it fits great! I'll be installing them next week (I need to do an updated video anyway).
TN_cactus
Jesse
Nashville, TN
IT
When will you have these back in stock?
WLFPIR8
Ethan
Central Ohio
whor.us
It will be a couple of weeks for the full kit to be in stock. I've got more parts on order, but it's taking a while. You can sign up for a notification on the product page.
BILKO
Bill
Philadelphia
2013 Ford Fusion, 2019 Ford Ranger
Hey everyone! I know it's been a while since I have posted. I've been working on new designs and products. I am rebranding to Bilko Auto and will soon be launching a website with a variety of products. Before I launch the website I figured I would list the new design on Ebay so you can order them before the website is up and running. I'm super excited about the updates I have made and to my standard flush mount outlet. It now is even smaller and snaps into place without and bolts. Below are a few pictures of the new design. Let me know if you have any questions and enjoy your weekend!
WLFPIR8
Ethan
Central Ohio
whor.us
Cleaner solution that cutting a notch in the panel.
Does the standard mount plate fit the panel hole? Or is that a panel specific mount ?
There’s a “size” option the the kits with Molle panel as an option. Plus you can get a replacement plate in that size too (it’s an option for that listing as well).
