ditch lights on tremor
KennethOwenReid
Liam
Chilliwack, BC, Canada
2022 Ranger Tremor Lariat
Mechanic
hey guys, been looking for a walkthrough on installing pillar lights on a tremor. found a few but mostly for fx4. i just have the 2 leds and some wire and solder. do i need to run a fuse? and tips or tricks would be nice.
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
Run the positive wire from the lights to the aux switch wire behind the driver side headlight. Run the negative to the battery or ground. No fuse needed on the Tremor as it is built in.
KennethOwenReid
KennethOwenReid
Liam
Mechanic
Thanks for the info. That’s great. I wasn’t sure about the fuse. Easy enough ??
One thing I will say about the ground. Go to a chassis ground instead of the battery directly. Why you ask? The is a sensor on the ground cable that meters the amp draw. Grounding to the battery bypasses that sensor and the Alternaotr may not charge correctly.
KennethOwenReid
KennethOwenReid
Liam
Mechanic
Good to know. Thanks for the advice. Do you know off hand where the nearest chassis ground is located? I’d like to have all the info before I go to install. Free time is scares these days
The entire chassis/body is the chassis ground when you think about it. If you follow the cable from the battery you wil see a good point on the drivers fender
