TennRanger
Looks good. I saw that they make a piece that goes on top of the shifter too.
Funny! I do have a Lincoln MKZ. Maybe Lincoln could call it the MKR. "R" for RangerYou all keep this up FORD is going to build a LINCOLN RANGER & charge double. They are all nice.
Hi Larry,You all keep this up FORD is going to build a LINCOLN RANGER & charge double. They are all nice.
They also charged a pretty penny for all that stuffing.Hi Larry,
Been there at Ford when we introduced the the world to the Blackwood Lincoln F150.... a premium Truck and it had premium appearance, but more importantly and unfortunately its poor sales was much of what the Blackwood Lincoln had over the Ford F150 was under the skin. Particularly the attention to sound deadening, ride and other NVH tuning options. Things the customer did not see, but if you owned one...it was wisper quiet. So what? If the customer does not see it...it is unappreciated. I spent much of my career in the realm of doing the unappreciated but making the vehicle more robust, quieter etc. Why? Because I internalized the improvements as I knew I did a good job that few would appreciate outside Ford..... Okay, now I reap the satisfaction when folks with older Rangers report their pleasure and lack of problems with their older Ranger Trucks! Means the work I did was worth it to have satisfied customers.
Thanks.Looks good. I saw that they make a piece that goes on top of the shifter too.
I would've never thought of ceramic coating it. I'm going to look into doing that before I get my dash cover. It maybe after the new year. Thanks for the idea.Thanks.
Fit is good on this piece and screen surround.
Yes the CD slot is a little odd but not terrible.
Was not sure how I liked the air bag covering. On the VW GTI forum everyone wanted the air bag warning covered as it was high on dash and centered. I am ok, but hope I am not missing any warning lights. Never understood why I needed to know that the airbag was off with no passenger. My 97 F150 had a key to turn off. Never used.
Fit is good. Similar to the others posted here. Someone said dash wood is real carbon. I find that hard to believe. Some models maybe but a Ranger? I do not plan to do shift area as gloss finish looks like it would get scratched easy. Maybe after many years if shift area gets damaged but I am normally good on interior. I did ceramic coat mine before install easier to clean and reduce scratching. 3 coats.
Feels good to touch.I would've never thought of ceramic coating it. I'm going to look into doing that before I get my dash cover. It maybe after the new year. Thanks for the idea.
Hi Pete,They also charged a pretty penny for all that stuffing.
But, at the time people did not buy expensive trucks. Not like today. A truck before it’s time.Hi Pete,
Yep....knowing where to put this "stuffing" by testing and analysis is part of the price you pay for a premium vehicle.
Alan, cold might be an issue. Clean area with alcohol wipes real good and make sure you put the adhesive promotor everywhere especially around the edges. Do an easy piece first ,then move up to harder piece and lightly stick it until you are happy with the alignment . Then firmly push it to complete adhere it. Good luck and enjoy the kit. BretJust got my email from B&I that my real carbon fiber kit has shipped!.....only took a bit over a week. Pretty excited to be getting it hopefully by the weekend.
For those that have done the install - how was it? Any tips/tricks? One issue for me may be that I am in Michigan and its pretty cold here - even in the garage - so that might be an issue?
Thanks Bret. Yep, I will be doing a thorough cleaning. I did read that the B&I Kit uses an adhesive that has built in promoter and a separate adhesive promoter is not included or necessary.Alan, cold might be an issue. Clean area with alcohol wipes real good and make sure you put the adhesive promotor everywhere especially around the edges. Do an easy piece first ,then move up to harder piece and lightly stick it until you are happy with the alignment . Then firmly push it to complete adhere it. Good luck and enjoy the kit. Bret
Mine all came with adhesion promotor as a seperate step. Just dont stick them hard to surface unless its lined up real good.Thanks Bret. Yep, I will be doing a thorough cleaning. I did read that the B&I Kit uses an adhesive that has built in promoter and a separate adhesive promoter is not included or necessary.
The cold though has me concerned.....
Are the pieces pretty forgiving as far as having to pick them/remove them for alignment purposes?
