D window steelies (16/17") with aggressive tires?
mm10
2019 Ranger Lariat SC FX4
Looking into options for a cheap steel wheel that's black and gravitating to the old standard D windows - does anyone have them on their truck with an aggressive tire in 16" or 17"? Can't find anything to reference on google and the Tire Rack visualizer doesn't quite cut it. Trying to avoid photoshopping to see if I'll like it before I buy. Looking for pics and feel/performance thoughts going from an 18" down to something with a bit more meat/sidewall. TIA
CATX
Will
2021 Ford Ranger TURBO
RedDakooter05
Illinois
2024 Nissan Frontier S 4x4
Are you talking about these type of wheels?
They're typically called "wagon" wheels if I recall correctly.
Have yet to see them on a ford ranger.
Gazmic
WA
Machinist
I wanted to purchase some from a local tire shop a few years ago. The salesperson said they don't make them in a 17" dia. and offset that works for the 265/70 K02's I was upgrading to.
Not sure how true that statement was.
Discount Tire
Arizona, USA
discountti.re
All Things FORD
Tire & Wheel Specialists
There are now a few options available. Take a peek at the Vision D Window wheel. Great styling and stance for an aggressive off road look. Great incentive available as well!
mm10
mm10
Yep, this is the style I was referring to. Seems like there's a few in size/offset but no one is running them
mm10
mm10
mm10
mm10
Nope no rub
Awesome. Last dumb question because I can't seem to find the specs anywhere - no adapter or anything needed right? Same bolt spacing and offset (or close)?
Littlezoo55
Coal Township, Pennsylvania
2020 Ranger XLT 4x4 super crew
Shop manager
Factory tires and wheels from Ranger are 255/65/17, I use them in the summer. I traded the Bronco in and the dealer didn't want the stock wheels so I tried them on the ranger and they went on with no issues at all. And they don't look all that bad.
Potlickr
Ontario, Canada
Ironworker
Here is my truck with the 16” factory steelie setup. Tires are Cooper Rugged Treks in 265/70R16.
Rangers don’t come with steel wheels in Canada, so I had to order the wheels and hub caps…
Not a fan of alloy wheels or anything over a 17”… I off-road my truck… Steels are much better for that
They aren’t black, sorry… I need to paint them in the spring.. Probably not silver.
