Climate Control Module Issues
VegasRanger
Las Vegas
2021 STX Crew Cab 4x4
Damper Salesman
My HVAC system is weird on my truck. Let's say I set temp on both sides to 68 degrees, the temp coming out is perfect, not too hot or cold. Then out of nowhere, the air coming out starts getting colder and colder and I have to constantly adjust the temp, 68, 69, 70, 71, gets warm, then goes cold again. The only way to get consistent temp is if I turn the temp way up, it stays hot, but then its way too hot for my taste. PIA to deal with in winter months.
Just had an issue with my climate controls. I always use Auto temp and set it at 70, works fine then suddenly it will only blow super hot air. Like it’s on high heat. Turn it all the way down and no changes. Turn on the AC and still only hot air.
Have an appt next Wednesday for another issue so I added this to the list. I told the dealer ny truck has 35,708 on it now and will most likely be over 36 by next week. She’s said “then it will be out of warranty. We can’t back mileage it and it doesn’t matter when you make the appointment.” Ugh.
My suggestion try not to drive the truck. That way you don't have to worry about the mileage issue. You can also attempt to contact Ford customer care but no promises
txquailguy
txquailguy
Biologist
Get a rental…I think that climate control module replacement cost BIG $$$$ out of pocket.
Rkmiller55
2019 Ranger Lariat FX4
Administrative
I have the issue where the Driver's side blows hot all the time. The Climate control housing needs to be replaced. I have 50k on it so it is not under warranty. $2200 to fix. I don't have the extended warranty. Pay now or pay later....
