I've never had a problem with the factory brakes on my Ranger. I'm doing this mod because I have always upgraded bakes on other vehicles I've owned at or around 30-40K miles, and in my case, have always had much improved braking.Brakes can be be a long rabbit hole to dive into. The factory pedal feel is much maligned around here. Most of that sponginess can be removed with a good brake bleed, and possibly a bit of pedal adjustment.
The Ranger is factory filled with DOT 4 fluid already, and although there are some braided stainless line sets available I'd consider those for more of an offroad ruggedness modification rather than performance.
Rotors and pads are available from budget setups all the way up to Pedders 6 piston BBKs. All a matter of what you want.
I don't believe our factory pads are ceramic, but I've used ceramic pads on a few vehicles and been very happy with them. Very clean, and much appreciated with chrome or lighter colored wheels.
I've found Ford factory brakes to be very good all around over the years. A very good balance between performance, noise, and longevity.
When the time comes for me to do brakes on the Ranger I'll probably go with a good set of aftermarket ceramics or OEM replacements, stainless lines, and factory rotors.
I will caution you not to cheap out on your brakes. Stick with reputable, well known companies or OEM.
Personally I'd stay far away from the cheap stuff like the kit linked to above.
I totally get it. It makes sense to "upgrade" when doing your first brake job. But in order to truly "upgrade" over most modern factory systems, you're generally going to have to spend some coin.I've never had a problem with the factory brakes on my Ranger. I'm doing this mod because I have always upgraded bakes on other vehicles I've owned at or around 30-40K miles, and in my case, have always had much improved braking.
So you called these cheap and said to stay away, can you tell me about your experience with this specific brand?
I mean, made in the USA, lifetime warranty against warping and cracking, and pages and pages of 5 star reviews. I don't need "big brakes" (won't be doing heavy towing), or red calipers, so when you compare these to the "brand' names" without the extras there really isn't much difference in the price.
If it's the same process as other Ford rear brakes for sure! I borrowed the tool and couldn't see doing it without.I had to replace my rear pads at 70,000ish miles. I blame the hill-start assist. I got Motorcraft. The truck stops just fine. I don't need a racecar, I have racebike and my fun street car. It's a truck, it'll stop.
And JFC the rear brake job sucks on this truck. So fiddly... Rent the tool for rear parking brakes from [Parts Store Name Here]
The ones where I brake and apply gratuitous throttle? Becuase them damn kids around here keep doing that...If it's the same process as other Ford rear brakes for sure! I borrowed the tool and couldn't see doing it without.
And pretty sure your early brake wear was due to them e' brake slides.
It's on the internet, therefore it must be true.i always take product reviews with a grain of salt.
theres no way of knowing if they are accurate or not.
Agree, but if you actually take time to read some, you can typically spot the real vs. fake most of the time. Also if you look at more than one source of reviews, that can help.i always take product reviews with a grain of salt.
