Catch Can removal
FusedLogic
Fred
2022 Ranger XLT FX4 Splash
Retired - Air Cargo Industry
Moral of this story: Ya’ll stop playing “drivetrain engineer” (by installing a “fix” that’s unneeded) and just start enjoying this great lil engine as is..
I'm with you on that. There's a lot of controversy when it comes to catch cans. Some experts say it isn't necessary, others say you shouldn't live without it.
My thought is, if the engineers thought it was necessary, they would have made it part of the system.
On the other hand, Ford did switch to a hood prop on my '22. Can they really be trusted? ?
dtech
colorado
Not necessarily true -" making it part of the system" as one of the realities of autos today is requiring less maintenance and depending on the operating environment a catch can may require frequent maintenance - as in checking and if necessary emptying the contents. Also it's is installed in the emission system - which is regulated by the EPA, which requires that most problems with the emission system are monitored and trigger a MIL when amiss, so adding that to a catch can system is going to add cost and complexity. The oil separator system on the Ranger may be sufficiently effective but I'd be surprised if most engineers disagree that a catch can doesn't add an additional layer of protection.
And just to add to the above there are engines from some makers - Ford included that use MPI along with GDI - primarily to "wash" the intake valves as with non gdi engines.
Sariandan
Kevin
The lowcountry of SC/GA
2022 Ford Mustang EcoBoost
Paramedic/Shift Supervisor
It's funny that I noticed the hoses starting to crack. Tonight, while driving home, I heard an unusual "woosh" sound coming from the driver side engine bay when I'd get on the accelerator. When I got home, I looked around and found that the hose that leaves the catch can back to the manifold had split down the middle. In the morning, I'm going to get a 5/8" section of hose to replace it. Thankfully, this is the one that goes to the top of the engine. Although, who knows how far behind the PCV line is. Mishimoto and their crap hoses. I'll probably replace both with some braided hoses, like the UPR system mentioned above, eventually.
task65
TERRYT
MO
2019 Ranger FX4 Lariat
Bridge Builder
Same here. They did the same offer for me but I declined. Sorry to any Mishi Fans out there but I would advise anyone to steer clear of their products based on this experience.
How did you get the hoses off? Please tell me. I hate this catch can
puckdodger
puckdodger
Oshawa
Perseverance. It likely helps that I worked in auto assembly for way too much of my life but I am very familiar with those big green CPA clips that holds them on. You need to kinda work the tips back and once they pop the hose comes off. You gotta feel around to find the little nubs at the sides.
Hope this helps even a little. Good luck.
task65
TERRYT
MO
Bridge Builder
I tried twice but will try again. Im thinking of taking it in to my dealer and have them get to them however they can. I dont care what it costs. They usually work with me pretty good on things like that. And thank you for the quick response
puckdodger
puckdodger
Oshawa
I hate giving in LMAO. Try using the side of a trim removal tool
TJC
I really believe FORD put those ports in a terrible place with regards to service. If the PCV valve goes south (as they do), it is going to be hell to replace it.
It was a $40 part when I purchased it, with the PCV valve integrated into the plate, so the entire assembly must be removed. To do so, it appears that the intake manifold must be removed! I do not see a way to easily get to the those upper plate bolts that are tucked under the intake manifold.
Anyway, this is the oil separator plate and the original hose.
