Fawnbuster
She is Hillary part deuxGreta has your IP address....
I have datalogs of before and after but I did charge pipes and the cat delete at the same time so it would be hard to tell which had the most impact. I can upload my logs if you're interested. As far as boost creep, I'm not entirely familiar enough with it to know what kind of issue it is.do you have any data into actual performance increase from JUST removing the cat? I'd be kinda surprised if it actually made a noticeable difference on a vehicle this new, other than just causing boost creep?
I don't have any sound clips of it before putting the glasspack in from the outside, just the sound from inside the cab during a short run. And yes, no foulers are generally used for spark plugs but the thread is the exact same size as the O2 sensor, you have to use a 1/2in drill bit to make space for the O2 sensor in the no foulers but it basically pulls the sensor out of the exhaust stream so that it doesn't trip the catalyst efficiency sensor. Works like a champ for a $5 fix lol.I want some sound clips as well. I like being obnoxiously loud, but then again I only drive the 2019 on Sunny days or weekends so going to work won't bother the neighbors (actually, my 2010 is also catted with straight pipes. lol)
Also, what is a no fouler? Isn't that what is used for plugs?
Thanks! Sounds pretty awesome. That little blue smoke puff at startup gave me flashbacks to my 350 TBI though.Here you guys go. Got a video of startup and idle as well as a video of it revving.
That's probably not a good thing lol. What all have you done to your engine upgrade wise?According to a friend that tried to keep up with me, he said it shoots flames and rolls smoke like a diesel lol. Rather run rich than lean for safety sake but I know that also means that there's a lot more power to be had within the tune itself.
