CAN’T SEE BEHIND YOUR RANGER? AUXITO LED REVERSE LIGHTS That Actually Work (2021-2025 Plug-n-Play)
AUXITO
Diamond Sponsor
AUXITO
AUXITO Senior Manager
If you're dissatisfied with the brightness of the original 7443 backup light bulb, read AUXITO's proper upgrade method—no hyperflash, no errors, just seeing what’s behind you.
⚙ WHY RANGERS NEED THIS UPGRADE
Stock GarbageAUXITO Solution
❌ 120 lumens✅ 2,000+ lumens
❌ 60° beam✅ 180°+ coverage (exposes ditches/hitches)
❌ 1-year lifespan (vibration kills)✅ 50,000-hour ruggedized
💥 THE RANGER-APPROVED KITS (Plug-n-Play 7443)
1. 2US6T SERIES
Why It Works For Trucks:
→ Dual-sided LED chips – double the output (3,200 lumens)
→ IP68 sealed – survives pressure washers/deep mud
2. 54H SERIES
→ Top convex lens
→ Zero camera glare – crisp image for factory/aftermarket cams
3. 2F23 SERIES
→ Built-in CANbus & resistors – zero error messages
→ Instant-on circuitry – no delay when shifting to Reverse
→ OEM-size housing – 100% stealth fit
🔧 3 NON-NEGOTIABLE INSTALL RULES
DIELECTRIC GREASE CONNECTORS – stops salt/mud corrosion (esp. plow trucks)
POINT LIGHTS DOWN 15° – illuminates ground, not camera lens (use zip ties)
TEST BEFORE ASSEMBLY – shift to Reverse before bolting housing (save 30 mins!)
All kits include:
SAE/DOT compliant white light (no illegal blue!)
2-year “Work or replace” warranty
Questions? Roast me below! POST YOUR NEAR-MISS STORIES – we’ll send fixes 👇
Light your way home,
AUXITO TEAM
Deleted User 38384
It would be SUPER convenient if y'all had a "Full Ranger Kit" that I could order to just DO the entire vehicle all at once with your best stuff. OR,,, y'all could join up with sponsoring my build. I post a ton of pics and I'm super gorgeous,,, like a "spokes model". I'll "rep" the brand hard... :like:
I filled a cart (on your site) last night with everything I "thought" would do the entire vehicle BUT,,, I didn't pull the trigger because of uncertainty.
1. 2US6T SERIES
2. 54H SERIES
→ Top convex lens
3. 2F23 SERIES
All kits include:
AUXITO TEAM
Can BLISS taillamps' LEDs be upgraded?
AUXITO
AUXITO
Diamond Sponsor
AUXITO
If the taillights/backup lights are already LED lights, these bulbs cannot be used for upgrading.
These LED bulbs are designed to replace original halogen bulbs or LED bulbs from other brand
AUXITO
AUXITO
Diamond Sponsor
AUXITO
Thank you, that's definitely a good suggestion! I'll do that next month.
Also, for products that you're unsure about, can I know the reason? If this is your first time trying our products, I'd be happy to give you a sample for free review.
Deleted User 38384
I just wasn't sure if I was picking the right bulbs for the right locations.
Deleted User 38384
I probably should have studied up on your product before I dropped $600+ on full LED headlights.
You know what would make a badass picture & video ? A side-by-side comparison...
1... Stock HL vs. Your HL
2... Your HL vs. Replacement LED HL
*winner take all !
My objective is to get rid of all that amber glow. I would like everything to be the same color temp...
I already have a plan to replace the Fog Lights that still gives me the ability to have amber fogs when needed...
But those headlights look like big orange softballs. 🤢
AUXITO
AUXITO
Diamond Sponsor
AUXITO
I probably should have studied up on your product before I dropped $700+ on full LED headlights.
*winner take all !
The brand-new headlight assembly is quite expensive, but it's brand new and can definitely give your vehicle a more modern and tech-savvy appearance.
Some models feature a sleek, flowing design for the DRL/parking lights, which looks even cooler. I believe this all-in-one product will make installation much more convenient.
LED bulbs are more suited for DIY enthusiasts. You can customize the lumens, color temperature, and other specifications to modify the lighting on your vehicle. However, selecting the right and suitable upgrade bulbs will require more time and effort.
For fog lights, the bulb model required for your vehicle (2022 Ranger) is H8. You can choose amber or white switchback LED bulbs available on the market (as a brand promoter, I'm not at liberty to recommend other brands, lol), allowing you to maintain the white color temperature at the front while switching to yellow when needed.
In addition, I highly recommend that you read my previous post so that you will know what type of light bulb you need to upgrade your lighting.
https://www.ranger5g.com/forum/thre...tion-your-bulb-size-chart-just-dropped.33584/
Deleted User 38384
Thx... I will.
Colo_Ranger
*winner take all !
what lights did you get?
Deleted User 38384
GTR Lighting Carbide LED Headlights.
I checked the manufacturer's website. Funny thing,,, it was cheap directly from the manufacturer. However,,, it only came with a 2 year warranty. The same lights on AmericanTrucks.com had a lifetime warranty. I called AT and they agreed to sell me the lights at the lower price + the lifetime warranty + free ahipping.
So, these will only work in XL trim level Rangers with serviceable halogen tail light assemblies and cannot be used in XLT or Lariat Rangers, correct?
