Looking for a hard cover (tonneau). Just went through a few posts and found the BAKflip MX4 hard cover. I like the this style, but was looking for something a little cheaper.By bed cover, do you mean flat (Tonneau) or a topper type cover? I just installed a soft cover (search my posts) but that isn't locking, though the gate locks so you may consider that locking. There are hard Tonneau cover that are more secure and combined with the locking gate are better. Some also may have a lock, but I don't know. Depends on what you really want/need.
Anything that is hard and secure will not be cheap. I have the Truxedo Sentry which is a roll cover with rigid aluminum slats and the canvas type cover versus vinyl. Have to open the tailgate to release and you cannot cut trough it to access the bed. I like it better than the in the bad retractable as you lose about 20% of the space, also does not block the back window when fully open like the rigid panels do. It was about $850 and installation was very easy, and sits pretty flush to the side rails.I just bought a 2019 Ford Ranger XLT with a 5 foot bed, and I’m currently shopping around for a bed cover that locks and is easy to access. Does anyone have a good suggestion?
Mine has rails, but it also has a quick disconnect, just slide the handle on each side while in the rolled position and it comes right out, the rails stay behind. When ready just drop it back on the tracks, slide the handle to lock in and roll it back out.Copy. I will tell you what I know. Some of the flush mounts require installing a rail, and that wasn't what I wanted. I wanted a very fast removal and re-install with no additional rail install. I landed on the soft Gator Tri-fold, mainly just to cover the bed for gas mileage (still debatable).
There are hard covers by Gator and others.
I do like the other options on the more expensive models. I edited my post above clarifying what I said for the OP's consideration.Mine has rails, but it also has a quick disconnect, just slide the handle on each side while in the rolled position and it comes right out, the rails stay behind. When ready just drop it back on the tracks, slide the handle to lock in and roll it back out.
Can you send me a link to the model? I like the way it looks and the fact it doesn’t cover the back window when fully retracted.Anything that is hard and secure will not be cheap. I have the Truxedo Sentry which is a roll cover with rigid aluminum slats and the canvas type cover versus vinyl. Have to open the tailgate to release and you cannot cut trough it to access the bed. I like it better than the in the bad retractable as you lose about 20% of the space, also does not block the back window when fully open like the rigid panels do. It was about $850 and installation was very easy, and sits pretty flush to the side rails.
Google is your friendCan you send me a link to the model? I like the way it looks and the fact it doesn’t cover the back window when fully retracted.
https://truxedo.com/sentry-ctCan you send me a link to the model? I like the way it looks and the fact it doesn’t cover the back window when fully retracted.
Where did you find the flag decal for the useless pass through window? I like that very much. I also have the tailgate letters but I did the Magnetic Gray over Black.I'd recommend a truxedo sentry ct or bak revolver x4s.
