Banks iDash
Colo_Ranger
Argh. Hundreds of dollars in custom equipment and freakin' electrical tape to make it fit. I know what happens when it's been exposed to heat and sunshine long enough.
I have had mine for about a year now, I think, and it hasn't changed at all. Still a snug fit.
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
Here's the opening of the Aeroforce in millimeters:
The Banks i-Dash without the adapter ring:
And the adapter ring, which looks like what I'll have to enlarge the Aeroforce to
(I'm not thinking of using a millimeter + of electrical tape, don't want adheisive melting in the summer heat and weeping out)
I just have to figure out a precise way to route it out 1.7 mm in diameter...
Fx4ranger2019Larait
Ricky
SoCal
2019 Ranger FX4 Larait
Sprinkler Fitter
I used a small piece of weather stripping on top never had an issue with weeping in summer I live in soCal temps in 100’s.
Racket
Here and There
Transient
Weather stripping is a 'better' solution than electrical tape and while it may seem appropriate for a truck I'd still want something as well designed as the gauge pod itself or in line with the cost and utility of the guage in this case. I'm not a perfectionist but I appreciate a well executed install.
Racket
Here and There
Transient
The Aeroforce gauge pod is a top quality accessory- the size an orientation is great.
And as I reported before, fitting the Banks i-Dash Pro needed some work. I wound up hand lapping the too big $10 Banks adapter with sandpaper with a little work on the Aeroforce with a file to make it fit.
Got it all together and now I'm starting to play with settings.
All I had to do to run the cable to the gauge was pull the trim off the windsheild pillar and I used a pry tool to hold the dash while I slipped it through.
Everything snapped back together.
Racket
Here and There
Transient
I'm trying the soft putty to set the guage securely and so far not that impressed. Must be a better solution.
Been driving with just the boost guage and liking the data (if I can trust it) and using it to adjust my driving.
Now I'm playing with gauge settings for HP and torque output...
But c'mon 400 HP at 0 boost? πŸ˜†
Dr3wDrop
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
Weird because that is a reading for the percentage of available power based off of that moments air density. 410% ??
Racket
Here and There
Transient
If it's an expression of % and no calculated value it's confusing.
I'm running a tune, probably snapped this pic at modest throttle.
Racket
Here and There
Transient
I changed the gauge to show HO/TQ based off the ECU and the readings have been interesting. I guess I could pull the microSD and graph out what power is being reported but I was amused seeing 350+ hp flash up at one point under heavy throttle.
Dr3wDrop
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
For anyone still interested in this post. Banks confirmed today that the new iDash Pro does read trans temp on the Ford Ranger 2019 - 2022. The older iDash classic does not and wont be receiving any further updates.
Racket
Here and There
Transient
I believe I read (haven't gone through the updated options yet) that the gear selection can now be displayed as well. When I have time to tweak it I'll follow up but this was the update:
Dr3wDrop
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
I can see what gear I am in with the iDash basic. Is what you’re describing different?
Racket
Here and There
Transient
My recollection back when this thread started was it was not available. The splash screen for my update mentioned adding it I believe and I did not have it initially.
