Leaves Between Bed and Cab
G-Force
New Jersey
2019 Ford Ranger, fx4, SuperCrew, Magnetic, 1989 AM General M35A2C 2 1/2 ton retired Air Force Deuce ( named Olivia after my granddaughter)
I just looked through all 11 pages of the Issues, Repairs, Rarranty, tsb, Recalls forum and did not see anything posted about this. If its posted in another forum l did not find it with a search. Since we are in the middle of fall up here in the northeast I noticed a very large accumulation of leaves in between the bed ad the cab, especially on the passenger side. Almost impossible to clean out from below, I had to adapt a piece of 1/2" pvc tubing to my shop vac to get them out. It appears they put a piece of rubber weatherstripping down at the bottom off the bed which blocks off the bottom so anything that falls down there is trapped. I really wouldn't have posted this but when I cleaned the passenger side I had some water drain out under the truck ( it had rained a couple of days ago up here) and all the leaves that i sucked out were sopping wet. I was just wondering if anybody else noticed a buildup of leaves or debri in this area.
Sandman Ranger
Pete
Lead Process Engineer
I noticed this pumping gas this week.
Good suggestion. Wonder if one can power wash out? Will try.
Design issue.
G-Force
New Jersey
Design issue.
I think its a design issue. The only reason I can think of for putting that weatherstripping down there is because there appears to be two what look like louver vents on the back of the cab one on thedrivers side and one on the passenger side. I was thinking they were worried about exhaust leaks possibly coming into the cab through then ( if in fact they are cab vents). I'm more concerned with the cab rotting out over time. Plus it was annoying the P#SS out of me for about 2 weeks.:(
Sandman Ranger
Pete
With the rear window the exhaust issue might be a reason. The bed has two plugs in this area. My bed cover drains through them. If there are cab vents also, then the strip would help prevent fumes. Most vehicles have vents in rear so these are normal.
Looks like a rust point if it traps things.
G-Force
New Jersey
Well the weathestripping they used is pretty soft and flimsy. Kind of like that cheap garage door weatherstripping you can buy at home depot. Its molded into a shape but its pretty soft. Almost like a foam rubber.
I_smell_like_diesel
Western Maine
2019 Ford Ranger FX4 Lariat
Self Employed
Maybe try a long reach air gun. Use these all the time to clean out leaves, bugs, and cotton wood seeds that accumulate between Super Duty condensers and rads.
Roofhopper
Ted
Fairfield OH
2019 Ford Ranger XLT FX4
HVAC Service Manager
No different than any of the other 7 or 8 trucks I’ve owned. A quick pass with the garden hose and high pressure nozzle usually does the trick, pressure washer definitely knocks them out
Alex
I noticed this same issue last night. I ended up using a quarter inch wooded rod to push the leaves to one end of the bed and out the bottom (trying my best not to scratch the paint), and then used some compressed air to blow out what was left. Does anyone know how durable the vents are on the back of the cab? When I was using the compressed air they were really moving, they look like they are made out of some type of fabric. I just don't want them to rip or fall out of there housing, it seems like it would be a big pain to replace or put them back in.
Arron
Arron
Seattle, WA
2019 Ranger SuperCab Lariat FX4 Sport Magnetic
Software developer
The vents are plastic with rubber flaps. They should hold up no problem to compressed air. They seem pretty durable.
landiscarrier
Landis
Pocono Mtns Pa
2025 Ranger Raptor
Sales
Went and picked up some mulch today and when they loaded it up, with a loader, some mulch fell between the cab and bed. When I looked in there I saw mulch and leafs from fall. How the heck do you get that stuff out of there?!?
landiscarrier
Landis
Pocono Mtns Pa
2025 Ranger Raptor
Sales
Ok. Thanks!
Just be careful if using a power washer there. It's a tight area and you don't have a lot of room to keep the wand back away from the cab and you could end up damaging the paint back there which could end up rusting. When you first pull the trigger it's going to be pressurized at +/- 2000 psi. I would use a regular garden hose from different angles.
landiscarrier
Landis
Pocono Mtns Pa
2025 Ranger Raptor
Sales
I’ve got to say this is a strange design in my opinion. I cannot get this crap out of there. A power washer and hose just get everything wet and water drain out underneath but none of the leaves and mulch.
maybe I’m a idiot but this is annoying! It’s a rust nightmare waiting to start!
