Backup Camera Malfunction
JasonT1273
Ohio, USA
Premier Service Consultant
I just bought a used 2019 XLT SuperCrew. My backup camera looks like trying to watch a scrambled cable channel back in the 80s then pops up the ever-popular Camera Is Unavailable message. I've tried a replacement camera unit to no avail. Has anyone seen this and successfully fixed the issue?
JasonT1273
Ohio, USA
Yes. No visible corrosion in the connector going into the camera. I should have mentioned that I checked that before the replacement camera attempt.
You will need to hook up scanner and pull any (B) Body or (C) Communication codes to pinpoint it down.
You might try running system self-test on the BCM, IPM, and APIM, running the test mainly on the IPM will initialize the rear camera.
Try those first, then post the code if no help.
Note: There are 2 other (exterior) inline connectors that feed the camera
C411
C422
JasonT1273
Ohio, USA
These are two additional points that may have corrosion or other connection issues then I take it? And as far as a code scanner goes, is that something I can do with Forscan or would I have to take it to a dealer?
Forscan will do the same
vanapagan
Gregory
Long Island, NY
vanapagan.com
2021 Ford Ranger XLT Super Crew
Cloud Computing Engineer
FordTechMakuLoco had a similar issue he posted on YouTube () where he had a Platinum F-150 that had a CanBus issue with a module that had water intrusion and he had to replace the taillights and the wiring harness to the tune of $5600 to the customer.
Symptoms were the radio started going screwy and then the whole system failed and the owner had a dead truck that had to be towed in.
I'm not sayin this is your problem but if you have the time go watch the video. Great insight into how to debug these vehicles and what to look for.
It may not be the camera or the connector but something totally unrelated to it that shares that wiring harness. Start disconnecting things on the harness until the problem stop or you run out of things to disconnect.
Jason B
2021 XL STX SE 4x2
machinist
My guess is that either Big Foot or a UFO/Alien was behind your truck, hence the blurry image.
The image display from the camera comes from the data bus - which is a shielded wire run- shield protects the run from interference from outside interference (of the run) itself
So the image can be distorted from a poor connection or the camera needs a calibration to initialize it.
When a system scan is done - it should generate a code - this code will pinpoint down what to check for the cause of camera distortion.
The scan and clearing of any codes might bring it back to normal.
If it does not then dig deeper into the cause, which is most likely a poor connection in the circuit
JasonT1273
Ohio, USA
C411
C422
I didn't see a C411 at that position. The pigtails of the tailgate lock and camera are simply loomed together and exit the bottom of the tailgate. Would it be underneath the vehicle instead of inside the tailgate itself?
As for the C422 I didn't locate any inline connectors fore of the driver's side rear wheel well until much further up toward the transmission. I did locate a large connector aft of the wheel and it was intact and without corrosion.
I am going to install the latest version of Forscan on my laptop and get the license so can I pull the codes, if any. Hopefully they will prove more enlightening. I will post back when I have those codes. Probably won't get to it until the weekend.
C411 is located underneath the truck, as you look up the connector is clearly seen as it is the first connector on the harness as it exits the bottom of the tailgate.
The location diagrams are general area and not the most exact and can be misleading.
C422 should be near the location shown - Manual states (Inside Left Frame Rail), so may not be easily accessible.
C422 is a big connector 34 Pin
JasonT1273
Ohio, USA
Thanks for that clarification. I think C422 Is the one I saw and checked then because I looked down the frame rail from the rear and it was the only one I saw. I will look again this weekend to be sure. Short of any visible corrosion or disconnect is there a cleaner you recommend using on the connectors?
Any electronics cleaner will do that has alcohol base, fast drying.
Such as CRC
Tom_C
Virginia, USA
System Admin, Retired
I have no idea, but I would guess the camera is digital. If that is true, then it's more likely a camera issue. Total WAG.
Edit: OP tried a new cam.
Just wanted to give you some other options for a possible fix, just in case the system needs a reset / reboot.
Disconnect Battery for 5 minutes or so
or
Hard Reset the Sync Module: But you may lose programmed presets (IDK)
Somewhere in the settings on the display is a reset option, I just don't know exactly how to get to it without physically doing it myself.
or
The system incorporates a few modules for the Rear Camera
Try Pulling and Reseating some fuses.
SYNC / APIM - Fuse 31 -- BCM (By your left knee) - Display Screen
DC/DC Convertor - Fuse 23 --- BJB (Engine Bay) - Powers the Rear Camera
BCM - (Lin 4) Communication to the Rear Camera, I think this is the input (switch) to power the camera when you go to reverse. (?) (Fuse 34) - BCM (by your left knee)
I'm out of options now without a code, hopefully one of these options will help.
