Anyone else notice their Ranger chugs gas when idling?
Daedalus9042
Steven
Seattle WA
2019 Ford Ranger XLT FX4
I can watch my MPG drop as I sit at lights, even when I already have 100+ miles on the trip my MPG can drop a few decimals when idling for only a couple of minutes.
Also noticed if I use remote start and let it sit for 3-5 minutes before taking off that it is sometimes up to .5 MPG off from where I left it.
I'm starting to think idling is one of the main culprits for some of our poor MPG ratings...
Note: I have auto start stop enabled but it doesn't work when using the defroster. This is documented behavior and expected.
Stic-o
Lake View Terrace, CA
Umm. Every car does this...:computerrage:
I wouldn't call it chugging, nothing like my 6.8 V10. :(
Daedalus9042
Daedalus9042
Steven
Seattle WA
It just seems much more substantial than any car I've driven in the past. Never noticed this in my WRX.
Anthony
Anthony
Connecticut
COO
Because when stopped you are factually getting 0 mpg which is also averaged into your trip computer estimates.
That would be the correct answer.
Daedalus9042
Daedalus9042
Steven
Seattle WA
Yes I am aware of how MPG is calculated. My point is that it seems that this truck uses a lot more gas when idling than other vehicles with similar power plants.
Daedalus9042
Daedalus9042
Steven
Seattle WA
And this is based on?
My thoughts are you are over analyzing the obvious
Dont forget that new vehicles are generally programmed to run rich for a determinate amount of time while they break in.
I'm at 4500 miles so I don't think I'm in the break in period anymore. Plus my MPG as reported by the computer is roughly 3 MPG lower when not using start stop, which I would say is significant.
StAugKid
St Augustine, FL
2017 Ford Fiesta ST
Assistant Manager Kay Jewelers
Is it actual fuel being consumed or is it just the calculation being lowered in the screen? If you manually calculate the mpg, is it lower? The computer will go down pretty fast since anytime you aren't moving, you are adding 0 to the calculations which will dramatically lower your average as being shown in real time.
Lrtexasman
Larry
Tahoe/Tundra/Fusion
Smaller tank so gauge drops faster.
khyros
2019 Ford Ranger Lariat Crewcab FX4
Are you overriding S/S? I know it's not designed to shut down the engine in all conditions (and extreme temps seem to be one the of the factors), but overall, the truck is designed to not be running (often) at idle due to the S/S functionality, so if you're turning it off, and then complaining about the fuel it uses when the engine doesn't shut off, seems a bit hypocritical. If it's just not turning off on its own, I will just say that when it warms up, S/S will function more frequently and you won't consume as much fuel at an idle.
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
The basics of averages over the course of 1000 miles hold truth here. Drive 20k miles, then see if it drops so substantially. Its all about sample size.
Its not chugging down fuel. Your looking at a small sample. Its also gets 99mpg while coasting!
