SurfnClimb
I've had the same thing happen a few times when doing a U turn on a hill. I park there regularly so I've had a chance to try different things. I stomp it after turning and there is no response - no revving, no clunking, just total silence. Eventually it starts to spool up and go but there is a scary delay before that happens and when it does take off it is much slower acceleration than normal. At first I thought it was the traction control, since something similar used to happen in my old car if it sensed tire slip, but I've tried turning that off and it makes no difference. It also continued to happen after I installed a livernois tune. It only happens in very specific situations, usually from a low speed roll with light pedal pressure. 99.9% of the time the truck takes off like a rocket which makes it even worse since I've come to expect being able to hit a gap in traffic on the fly.
My theory is it's something in the ECU getting confused by the sudden shift in pedal input at low speeds. It doesn't like to drop into first unless it is at a stop, but to get power if its rolling in low RPM third or fourth it has to drop down. Something about that freezes up the shift pattern. The shifting is otherwise flawless so I don't think it is a transmission issue.
