AC Condensation
RedDakooter05
Illinois
2024 Nissan Frontier S 4x4
It'd be hilarious if the drain is just dumping the condensation over the frame rail where it just sits and rusts...
BladeRanger
BladeRanger
Bladimir
Escondido Ca
Ranger 2020 XLT FX4
Electronic Engineer
The wife's GLK does something similar so that no water drips on the garage floor. I haven't really noticed any from the Ranger. I'll have to pay closer attention but haven't seen anything on the floor except for the nasty tailpipe droppings :(
That's all I got on my garage is the tail pipe dropping.
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
I actually had a massive puddle under my ranger in RSM the other weekend after sitting for a while. Ours will eventually drop condensation, but I have noticed that it does seem to take longer to do, unlike other vehicles (even my other Fords).
SigOris
Greenwood Maine
Retired DoD EE
With my Highlander, I see lots of AC condensation but with the same weather (yesterday was 114 degrees with about 15 percent humidity) I never see any from the Ranger. I find that strange. I have no indication that the drain hose is plugged.
I hope I never see 114 temps like you hope not to see my 15 degree temps ?
Radioman
Kent
Roseville, CA
True John. If I want to play in the cold during the winter, I drive into the Sierras, and then, when I have had enough, I drive out of the Sierras to the valley where it rarely gets down to 32 degrees. :handsinair:
User79
Justin
2019 Ranger XLT
It will take a little time for the condensation to reach the floor. It drips just above the transmission into a pocket, the pocket has to overflow before you'll see it on the ground. The pocket is visible from under the hood, if you look behind the engine you won't be able to see the drain tube but you should see the drip & puddle.
I am battling an issue with the condensation from the evap lines in the cab dripping & soaking the carpet. Local dealer has performed the tsb but it's still happening.
BladeRanger
BladeRanger
Bladimir
Escondido Ca
Ranger 2020 XLT FX4
Electronic Engineer
Thanks for the info, hope they can fix your issue soon. One of my co-worker had a Ranger as well and his AC condensation is dripping on the floor when used.
Do you see the AC condensation dripping underneath your rigs when using the AC?
On my other SUV, I can see the condensation dripping when AC is used but not on the Ranger. I had the Ranger for over 2 years and just noticed this in last couple of months since it's been super hot lately and AC is at full blast.
It's always hot and dry here and I've never seen any under mine either. Like you I only see the tailpipe dripping but until now I've really never gave it much thought. Thanks, something else to ponder now! ? ?
Make sure there's no fuel in your oil...or install a tail gate damper as soon as possible...
This has to be the reason! :like::rockon:?
