- First Name
- Sid
- Joined
- Mar 5, 2019
- Threads
- 67
- Messages
- 9,198
- Reaction score
- 28,381
- Location
- North Carolina
- Vehicle(s)
- 2019 Ranger, 2003 MINI Cooper S, 2021 Honda CT125
- Occupation
- NWO Robot Polisher
- Vehicle Showcase
- 1
Did he even solder before applying the liquid tape?!HI Pablo,
These last two pictures show guaranteed wire shorting due to abrasion...You need to protect the red wire or the black wire when running through metal like you show... You have a headache in the making. Use a bit of hard plastic wire wrap convoluted abrasion tubing. You can also use rubber vacuum tubing segments secured in place with adhesive. Also, split wire grommets will work...just do not have a sheathed wire rubbing on metal.
Good luck!
