295/70/17 on ‘19 ford ranger
Joeranger96
Joseph pascua
2019 ford ranger xlt fx4
Military
Hey whats up i just recently swapped my tires to 295/70/17 from 285/70/17 and not gonna lie it gave me a little more contact surface im just worried that i might need to re gear anyone here have 295/70/17? I
rang19ca
Chuck
Carpinteria Ca
Retired Diesel Mechanic
Do you have clearance when you rock the truck while turning? If not you may have to install ReadyLift intrusion bars. Changing the differential gears is a whole other issue. Good luck.
COblue
Ross
SLC, Utah
Blue Ranger Lariat, bone stock
Gears are welded to the carrier in the rear, not as easy as a gear swap unfortunately
There’s some glare in the photo but it looks like he might have already removed his OEM crash bars.
Joseph, did you?
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
I don't think there are any other gears available. Reprogram the tire size in Forscan and the transmission shift points will adjust.
Joeranger96
Joeranger96
Joseph pascua
Military
Joseph, did you?
Sorry for the late reply and yes i did cut the crash bars and trimmed the fender liners to mitigate the rubbing so far no rub on these 295s on 2 inch lift and +18 offset wheels
Gsd1976
Las vegas
Ranger
Construction
I'm running 295/70/17. I put in a livernois 91 octane performance tune shortly after the tires went on. Woke it right back up. I can smoke the rear tires. No gears needed....yet.
