2020 ranger. Less than 9k miles. Driveshaft bolts missing
WOADKIL
Wil
Cyber Orange County, CA
RETIRED ENGINEER
Threads are fine. No scarring. Other 2 bolts do not show signs of removal. Just went to ace. Flange bolts to match original. I will use blue loctite. I’m aggrieved.
Grade 8 bolts I hope.
KnightWolf
Stu
Maple, ON
2021 Ranger Lariat FX4
IT Consulting
I know the supply chain shortages are nuts, but this really takes the cake!
Mrmonk7663
Mrmonk7663
Michael
Houston
2020 Ford Ranger
I would just order Ford part....not hardware store.
Hardware store was to get me through the day. I’d rather have 2 hardware store bolts than 2 missing bolts. Tomorrow Ford “supposedly” will put new ones the “pulled” off a truck at the lot. Guess that buyer is screwed too.
Mrmonk7663
Mrmonk7663
Michael
Houston
2020 Ford Ranger
The factory bolt is a 10.9 grade metric flange head m12x1.75-40 bolt with a 15mm head.
Gotta remember...SAE hardware and metric hardware are graded differently.
5.8 metric is approx a grade 2-3 sae
8.8 is grade 5 sae
10.9 metric is grade 8 sae.
Most hardware (Lowes, Home Depot, Ace) is either/usually 5.8 or if your lucky 8.8, which is generally for homeowner type applications or light strength automotive applications like panel attachment, ect.
10.9 is the automotive grade for high strength applications.
And, for high strength applications you don't want to substitute stainless steel hardware due to it composition stainless steel hardware is much more "brittle" than standard carbon steel. There is high strength grade 5 and 8 stainless but it is hard to find,,,never at your local hardware store.
onobeka
Romania
2018 Ford ranger 2.2 European model
8.8 would be fine, 10.9 better. For example the tow ball 2 bolts on EU ranger are M16 8.8, and those are supposed to hold a pulling strength of 3.5t. Yes, the driveshaft mount is about sheering force, but those are 4 M12 bolts. God knows how much driving the OP did with only two.
Good find OP! Your “mod” :( should give you peace of mind. Probably Ford forgot to mount two bolts, very solid QA they are doing :(.
One of the photos the OP posted shows the OE bolt and it appears to be a 10.0 or 10.9 on the head, indicating a grade 8 equivalent. Definitely would not want to go to a lower rated bolt.
I just crawled under mine, a 2021, and those bolts are definitely marked 10.9 grade...a grade 8 equivalent.
Markubis
Nashua, NH
Mechanical Engineer
BlackRanger01
Larry
New York
2021 Ford Ranger Lariat Super Cab 4x4
IT
Well ok, with recent new vehiciles, I always go for genuine stuff. It's just I M O.
RedDakooter05
Illinois
2024 Nissan Frontier S 4x4
What day was your truck built on, out of curiosity.
ctechbob
Shawn
2020 Ranger XL/FX2/STX
Adult Daycare
$10 those bolts were never in there from the factory. The threadlock that Ford uses on them you're lucky to get them out without heat from a torch, there's no way they're backing out if they were in there, unless they were installed without threadlock, but I will also wager that the threadlock comes on the bolts from the manufacturer.
I remember back a few months ago someone posted about finding some extra hardware, a bolt, that he found in his engine compartment.
I wonder...maybe...no, it couldn't possibly be one of the OP's missing bolts ! :LOL::LOL::LOL:
Mrmonk7663
Mrmonk7663
Michael
Houston
2020 Ford Ranger
Lol who knows. I’m heading to dealer in a few to get the new bolts installed. I went ahead and did my exhaust last night. I’ll post about it after I finish spark plugs and tune.
