2019 Ranger 2.3 ecoboost no start, low compression
Just curious if you ever got the truck to start or isolated the issue.
ctartm
Art
Connecticut
Yes. It was a cam phaser, and a vvt solenoid with a timing chain
Awesome - The Solenoid moves the Phaser, and it order to replace the Phaser, the Chain has to be removed. So, either the Solenoid was holding the Phaser, or the Phaser was stuck. So, they addressed both possible issues.
TJC
Try unhooking battery and holding terminals together and see if it causes a reset also pray while doing this and have a beer with a anti-anxiety pill.
If you are going to do this use a 1 ohm high wattage resister. Without it there is a possibility of blowing a board due too power draw from any charged caps in the system discharging. Bleed them down slowly (just a second or 2 in our time, but eternity to a logic circuit).
The safest way to reset the KAM - is via Scan Tool
TJC
Agreed, but if you ate going to pull the cables and short them, it is best to put some resistance in there.
