1" wheel spacer sources?
Thanks but Bora appears to be making them only on demand. I had an order through Stage3 in August but canceled them when I saw they had many Fabtech in stock last Thursday. I ordered a set and asked for the Bora to be canceled. Apparently, someone dropped the ball and didn't ship my order out and the stock got depleted. Now I'm stuck with a canceled Bora set and Fabtech is now at least a month out.
NvrFinished
Shea
SoCal
2020 XLT 4x4 Rapid Red
That's a drag. I wasn't aware that spacers where such a hot commodity. The only reason I knew of Bora was from reading a thread yesterday where someone used them.
NvrFinished
Shea
SoCal
Most wheel spacers like these are hub centric in order to ensure a good balance for the assembly. The Toyota's have a larger center bore so you would be losing that feature. I personally would not opt for a spacer that was not hub centric.
StezenW
Stephen
Atlanta
I bought a set of wheel spacers from wheel adapters USA, this was the listing I bought from. They took about 1.5 weeks to ship but arrived quickly after that. Very high quality and they served me well for 3k miles until I upgraded to different rims.
Unfortunately these are 1.5"...more than I need and they're also out of stock...
You know, I don't think Ranger's hub are hub centric as the hub doesn't locate anything...it's bolt centric...
NvrFinished
Shea
SoCal
I don't believe so. There are 4 tabs around the hub
No, it's hub centric. There are 4 tabs on the hub that center both the wheel and the rotor.
https://www.fordpartsamerica.com/oe...hbmdlciZ5PTIwMTkmdD14bHQmZT0yLTNsLWw0LWdhcw==
Yes but they don't touch my wheels center bore (Fuel Shok) and they've never had any problems...anyone poke Phil on this?
NvrFinished
Shea
SoCal
The Fuel Shok wheel is not hub centric. Many aftermarket wheels are not because it would require carrying multiple part numbers of the same size wheel, bolt pattern, and offset. They make the center bore large enough to fit all applications. It saves them money. Bolt centric wheels do not always center perfectly and can create balance issues on vehicles that are sensitive to such. This is why hub centric rings are popular. High end performance oriented wheels are almost always hub centric. For example, the BC Forged track wheels that I use on my Mustang are hub centric.
If you introduce a bolt centric spacer with a bolt centric wheel, you are only increasing the chances of creating a vibration and ride issues. And with two different bolt on assemblies holding your wheel in place, it's not the most comforting feeling.
Sorry to be the wet rag in your search. I used to be in the tire and wheel industry years ago and I know how these problems develop.
Haha...I appreciate your input...I have much experience with sports cars which are very sensitive to hub centricity...for some reason, my Ranger is not affected by not having hub centric wheels...probably having 6 studs helps tremendously...
