Wiring for new Cap
Shanewdude
Shane
Canada
2022 Ranger Tremor
carpenter
I’ve had my truck for two years now, and the tri-fold tonneau cover that I bought new with the truck is falling apart. Also, I’m looking to keep rain and snow off my tools, and make accessing tools easier. So I’ve bought a cap (topper?), and will pick it up this weekend.
Thanks to this forum, I think I’m well prepared for wiring it. The cap has canopy lights, camping lights, and USB charging that I will power with a harness from Wolfhaus.
That leaves the third brake, reverse and marker lights that I need to tie in to the driver side tail light.
I’m using tinned strand marine grade 14 AWG copper wire. I need 5 connections to the tail light harness, which I will make with T-taps. I’ve added heat shrink adhesive tubing to the paddle connectors, and will be using dielectric grease at the connectors. The other ends will get heat-shrink connectors. The whole bundle of wires are wrapped in a protective sheath.
At this point, I’m not sure how much room I have to make all 5 connections at the tail light. I’m also not sure if I will have enough room for the whole bundle to route it up through the bed.
I have found pin diagrams here in other threads, hopefully they are the same on my truck. It’s a 2022 Tremor Lariat, Canadian market, and if anyone has the pin diagram specific to my truck that might help reassure me. I’ll post the one I got from another post here again.
More pics to come when I start making connections.
Shanewdude
Shanewdude
Shane
Canada
2022 Ranger Tremor
carpenter
Mods, perhaps this is in the wrong forum… feel free to move it or let me know and I’ll delete it and repost.
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
I'd say use the 4-pin trailer plug if possible, then you only have to tap into the backup light wire.
That's what I did for my light bar.
I had a cap on the Sport Trac I used to own. It only had a third brake light, I got a cheap boat trailer wiring harness to run from the plug up into the cap. I found I needed a third brake light module (Amazon, $17) or the brake light on the cap would blink with the turn signal. You connect both turn signal wires to the module and one wire comes out (plus a ground) to connect to the third brake light.
Shanewdude
Shanewdude
Shane
Canada
2022 Ranger Tremor
carpenter
Thanks for the advice, definitely have to consider this. What is the advantage!
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
It's easier than splicing wires.
For my light bar I popped out the left license plate light, ran the wiring harness under the bumper attached with a few zip ties to the 4-pin plug, then put the license plate light back in.
Shanewdude
Shanewdude
Shane
Canada
2022 Ranger Tremor
carpenter
Ah, cool. I assume that I would have to unplug the cap then I tow something.
RAYJAY
UNION DALE PA
can't will trip out the trailer towing sensors
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
Unless a splitter exists, yes. But then the brake on the cap might not matter anyway.
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
Which disabled the auto stop/start, so I don't have a problem with it.
What it will do is disable the rear parking sensors and disable cross-traffic alerts and messes with your BLIS sensors. Not disable ASS, what disables the ASS is pressing the tow/haul switch.
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
Okay but I have a poverty-spec STX that doesn't have all the extra electronic stuff.
I can tell you that my tailgate light bar plugged into the 4-pin trailer plug does indeed disable the ASS without pressing the tow/haul button.
Shanewdude
Shanewdude
Shane
Canada
2022 Ranger Tremor
carpenter
It’s looking like T-taps into the tailight wires are the way to go.
Still open to other suggestions. Convenience is second to quality.
Shanewdude
Shanewdude
Shane
Canada
2022 Ranger Tremor
carpenter
I thought about your suggestion, thanks for offering it. I do tow quite often, which is why I’m not going to use the trailer wiring.
pismo1
Temecula,Ca
2020 FX2
For just the brake light.That is all I did and ground.Easy and took no time to do and no issues.
Shanewdude
Shanewdude
Shane
Canada
2022 Ranger Tremor
carpenter
Got the cap wired up (except utility and dome lights; waiting in the Wolfhaus harness).
The pin diagram is not identical to my 2022 Canadian market Lariat Tremor! It made me kind of nervous. Pin 9 is NOT blank! However, if you start at pin 1 and move up, pin 1,2,3,4and five are the same. I tapped into the ground, brake, parking, and reverse wires. Everything is working as it should.
