What is the purpose of this !!!
BladeRanger
Bladimir
Escondido Ca
Ranger 2020 XLT FX4
Electronic Engineer
What is the purpose of this? ( see pics circle in RED). It's just below the housing of the front shocks. I noticed that my Upper Arm Controller would rest on that stuff. I was inspecting some rubbing noise when I step on the brake and noticed after I jack the front end one at a time on each side that the Upper Arm Controller would rest on the metal. I assume having same issue when off roading. Is this the stopper for over extending the shocks?
GitRDone
Andrew
Orlando Fl
2020 XLT
Real estate management
Is this item plastic? I'm thinking it's just a splash shield to protect the shock. And if you were running through terrain rough enough to make it rub, you wouldn't hear it above the frenzied screams of your passengers.
BladeRanger
BladeRanger
Bladimir
Escondido Ca
Ranger 2020 XLT FX4
Electronic Engineer
Its made of metal.
MikeyB
NYC
It looks like a rest for the Upper control arms, for when the truck is on a lift, just my 2c.
I would be more concerned with the upper part of the coil spring,in pic 1, it looks like it's rubbing on that black bucket(?)with FOX written on it. Is that normal?
Waltztj
Walt
2021 Ranger Xl
That is from the forming process and it is needed cause it stiffens the straight part
Hi Bladimir,
This is a stiffening flange that was likely needed due to strengthen the part. Just speculation but you see the holes in the flat surface... They may have experienced cracking at the holes and the flange would stiffen and prevent cracking... You certainly do not want to remove this....looks like the UCA is poorly designed....JMO
BladeRanger
BladeRanger
Bladimir
Escondido Ca
Ranger 2020 XLT FX4
Electronic Engineer
Hi Bladimir,
Thanks for the info, I might have to go to a different UCA. I measured the original UCA and the width were thesame.
BladeRanger
BladeRanger
Bladimir
Escondido Ca
Ranger 2020 XLT FX4
Electronic Engineer
Well this Upper Arm supposed to be design for the Ranger but looks like I will need to search for a wider upper arm so it doesn't hit on the flange.
Aonarch
Alec
North GA/ Montana
Bad UCA design.
You don't need a wider base, just different geometry of the tubes to the ball joint.
dtech
colorado
was put there so it could be de-contented.
BladeRanger
BladeRanger
Bladimir
Escondido Ca
Ranger 2020 XLT FX4
Electronic Engineer
Bad UCA design.
Yeah, looks like I will need to start searching for a different UCAs, I compared the inside length of the UCA and it's pretty close to the original UCA but the geometry is different. The distance of the flange is almost same as the original UCAs ( 2nd pics below) . Ford suspension Engineers did not give a lot of room.
CO2Ranger
What UCA are you running?
Hounddog409
Tod
Ohio
F150
Hi Bladimir,
That top of the spring cover, that has fox written on it is bent. Now hitting spring???
What did you hit?
