OFC Ranger
- Thread starter
- #16
Yeah that makes sense I got a few things I can try before I just will assume that that's happening and leave the signals disengage for now and just deal with the hyper blink.I think you have to break this down into buckets to diagnose.
This get's convoluted trying to type out the scenario, but here's the ole college try.
You have two circuits, left and right, with four current draw sources.
With everything stock you get a hyper-flash which points to the BCM interpreting the circuit as being under drawn on current, ie. bad bulb or replacement bulb drawing less current than expected.
- Left stock light housing
- Left after-market signal
- Right stock light housing
- Right after-market signal
In one setup the after-market signal does not function but if you swap to the other it functions as expected but you still get hyper-flash in both scenarios.
It's possible that the after-market signal went into thermal runaway damaging a circuit on the BCM resulting in a loss of its ability to read the current on the line and enough damage was done that now it puts out less current than the other side. There is enough current available for the stock LED but not with the addition of the after market signal. The after-market signal may (most likely) have a higher current draw demand than the stock light housing.
