Water in HVAC system?
VegasRanger
Las Vegas
2021 STX Crew Cab 4x4
Damper Salesman
Good morning gents.
I recently (last few weeks) noticed in the mornings as soon as I turn on my HVAC I am hearing water sloshing back and fourth somewhere from the center of the dash. I haven't used my A/C in months since its winter, heater only. Have not seen any water inside the cab or anything to indicate a leak, but I can loudly hear the water sloshing.
Anyone else notice this? Normal?
Rp930
Denver
‘19 Ford Ranger Lariat,MB GLK250,’21 Shelby GT500
You need to check the a/c condensate drain.
VegasRanger
VegasRanger
Las Vegas
Damper Salesman
Know where it's located? Easy to get to? I find it weird I recently started having this issue even though I haven't turned on the A/C in at least 2 months.
Rp930
Denver
I’m sure somebody here knows where. Probably in the tunnel under the dash area or near there.
Just found this: The drain is against the firewall just left of center just above the transmission
Jason B
Louisiana
2021 XL STX SE 4x2
machinist
Whether you are cooling the truck or heating the truck, the AC compressor runs to remove moisture from the air, else you would be driving around with fogging windows. You can turn the AC of by hitting the AC button, if it's lit the AC is on.
Here is a link that may help.
Ranger Condensate
