Using 265/65/17 or 255/70/17 on a 19' Sport XLT 4x4 Non FX4
JaysOnTheEDGE
Jay
Office Equipment Technician
Hello
I read the master tire threads already didn't really find an answer. Got a 19 Sport 4x4 XLT with the factory 17" magnetic wheels on a stock front suspension. Am I okay to run the stock FX4 size 265/65/17 or a 255/70/17 size with my setup. Is there anything different about the FX4 front suspension that will keep me from running that size?
I am assuming the control arms and the spindle are the same the only difference is the shock and the coil spring? I don't want to go crazy big as fuel mileage is important to me but these stock bridgestones have got to go i need something a little more durable and would like something just a hair bigger.
Thanks
geophb
Mechanical Engineer
With the sizes you mentioned the dimensional diff based on numbers alone is the 255/70/17 is only .6 inch bigger in dia.
Almost negligible.
265/70/17 might be what you are after
Edit: unless that was a typo
Toytec
Central NC
This was my thinking as well OP. The B/S 255's are 30.1" . The 265/70's are 31.7" <-----THIS is what should have came on the 4x4 truck. Don't matter if it FX4 or not.
You will be pleasantly surprised on looks and handling. So glad I got rid of those Bridgestones.
Heads up, though. Your speedo and odo will be off 3-4mph and your spare will no longer match same rotation (revs per mile)
JaysOnTheEDGE
JaysOnTheEDGE
Jay
Thanks all for the feedback,
John(Toytec) do you have any shots of your ride with the new tires. and what did you get? looks like we have the same truck.
Toytec
Central NC
Must have tossed the photo, but here's someone else's w/Falken's
Hounddog409
Tod
Ohio
F150
Hello
Thanks
Isn't 265 65 17 your stock tire size?
JaysOnTheEDGE
JaysOnTheEDGE
Jay
My stock size is 255/65/17 since it’s a sport trim
GTGallop
Greg
Anthem, AZ
www.qrz.com
Program Manager
I'm 255/65/17 Stock too on an XLT 4x4.
IMHO, I'd go as tall as possible first and then start widening out if there was dimensional space left.
Fenske
Craig
Ranger2025!
2020 Ford Ranger Crew XLT
purchasing
I am also looking to go down this path so I have a couple questions:
1. Is there a way to have the speedo recalibrated?
2. Is the rotation going to cause damage to the point the spare should be changed as well?
RangerPNW
Thomas
Santa Fe, NM
1. You can recalibrate using forscan, there's a few posts on here going over how to do that. I know I've posted a few times about it.
2. Ideally you'd have a matching spare, yes. However if you're just limping to a shop to get it repaired for a short distance, should be fine. I've done it in the past and its less than ideal but going only a few miles isn't going to cause catastrophic damage.
Fenske
Craig
Ranger2025!
purchasing
Thank you for the quick reply.
1. I have heard of this and not comfortable with being able to do this... Truthfully, I would be willing to pay someone to complete it. Are there shops perhaps in the Buffalo area that can do this?
2. I would think best option would be to simply replace the spare as well.
21SCAB
Ken
Louisville, KY
2021 SCAB Ranger XLT
1). Just buy an adaptor and download Forscan and get a free 2 month license. Change the tire size in mm and go from there. It's really really easy to do and there are dozens of threads on it.
https://www.amazon.com/dp/B081VQVD3F?ref=ppx_yo2ov_dt_b_fed_asin_title
OBDLink EX FORScan OBD Adapter, $59.95 on Amazon
I'm not being a dick, but it's 1000x easy than even changing oil. So simple, just trust me on this.
Fenske
Craig
Ranger2025!
purchasing
Well, I guess it wouldn't hurt to learn how to do this. I will buy this, download and see what I can figure out.
