Normal Operation and Fault Conditions See Trailer Connected/Disconnected And Trailer Lighting Status. REFER to: Message Center (413-01 Instrumentation, Message Center and Warning Chimes) . Possible Sources
BC1 CHECK THE MESSAGE CENTER OPERATION | ||||
BC2 PERFORM THE TRM (TRAILER MODULE) SELF-TEST | ||||
BC3 PERFORM THE IPC (INSTRUMENT PANEL CLUSTER) SELF-TEST | ||||
BC4 CHECK THE GWM (GATEWAY MODULE A) DIAGNOSTIC TROUBLE CODES (DTCS) | ||||
i didnt, they didnt have a way to even confirm its function which i didnt really like. basically got the truck back with “we think it works” ha. i mean, it happens, but im surprised they dont have a way to confirm it.I had to work this morning so I had access to my Ford Software. Your problem has a pretty detailed pinpoint test they should follow. The message that is flashed on the dash for when the trailer is connected goes through some pretty intricate strategies before it reaches the IPC. However, as long as the problem doesn't go intermittent (the bane of my existence), it should be relatively easy to figure out. Did you drop off a trailer with the truck for them to test with?
PINPOINT TEST BC: A TRAILER CONNECTED STATUS MESSAGE IS NOT DISPLAYED WHEN A TRAILER IS CONNECTED
Possible Sources
- Trailer lighting concern
- TRM concern
- GWM concern
- IPC
BC1 CHECK THE MESSAGE CENTER OPERATION Is the door ajar RTT indicator off with the door closed, and on with the door open?
- Ignition ON.
- Close all doors and the hood.
- Clear all message center warnings by pressing the OK button for each warning present.
- Monitor the door ajar RTT indicator.
- Open the driver door.
- Clear the message center warning.
Yes GO to BC2BC2 PERFORM THE TRM (TRAILER MODULE) SELF-TEST Are any Diagnostic Trouble Codes (DTCs) recorded?
- Using a diagnostic scan tool, perform the TRM self-test.
Yes
REFER to: Trailer Lamps (417-01 Exterior Lighting) .
No GO to BC3BC3 PERFORM THE IPC (INSTRUMENT PANEL CLUSTER) SELF-TEST Are any Diagnostic Trouble Codes (DTCs) recorded?
- Using a diagnostic scan tool, perform the IPC self-test.
Yes REFER to DTC Chart: IPC in this section.
No GO to BC4BC4 CHECK THE GWM (GATEWAY MODULE A) DIAGNOSTIC TROUBLE CODES (DTCS) Are any Diagnostic Trouble Codes (DTCs) recorded?
- Using a diagnostic scan tool, check the GWM Continuous Memory Diagnostic Trouble Codes (CMDTCs).
Yes
REFER to: Communications Network (418-00 Module Communications Network, Diagnosis and Testing).
No INSTALL a new IPC. Refer to the appropriate Removal and Installation procedure in Section 413-01.
