Trailer Lighting Module Fault. Where is the Module?
FerdRanger
Ferdinand the Great
Central NY
2020 Ranger Lariat Sport 4x4
no thanks
Got a “Trailer Lighting Module Fault See (useless) Manual” message on the dashed followed by ”Trailer Right Turn Lamps Fault Check Lamps”
I don’t have any TBC so I’m NOT talking about the trailer brake control module
tried two different 1157 bulbs and both work when truck is locked and unlocked with FOB so I fear its the lighting module
anyone know where it is?
I searched for the part and came up with LJ6Z19H332A that costs about $135, but shows its in the passenger compartment of a sedan??
I’m trying to decide if it’s DIY or a dealer / extended warranty job
RangerBill
The TRM (trailer module) is located up under the passenger side of the dash. It has a 12 pin connector, a 2 pin connector, and a 4 pin connector. Are you saying that the right turn bulb on your trailer lights when you lock the truck, but doesn't light when the right turn signal is on?
These relays have been omitted and full control is from the TRM.
FerdRanger
FerdRanger
Ferdinand the Great
Central NY
no thanks
that is correct… right trailer bulb is getting power when I use the FOB, but using the turn signal lever causes the fault message and dash indicator light hyper flashes whistle the bulb does nothing
without the trailer, works as expected
sounding like someone who fits under a dash job…no?
RangerBill
It might be a resistive connection to the trailer turn signal wiring or in the truck. Are both trailer turn signal bulbs the same brilliance when you lock the truck and they flash? If the right one is dimmer, then there is a poor connection in the wiring. Do you have another trailer that you can connect to your truck for a test? This would narrow down the problem to the truck or trailer wiring.
FerdRanger
FerdRanger
Ferdinand the Great
Central NY
no thanks
left trailer signal works fine
using the fob, both sides bulb’s turn and brake filaments light up
right may be a bit dimmer…hard to tell
No access to another trailer, but that would be a good check
he goes in thursday for moderate oil drips after having the dealer do the “works” so I’ll see what they say
was trying to get intel before that and you’ve given me great info
thanks
RangerBill
thanks
You're welcome. If the right bulb is dimmer than the left, that could trigger your fault message, as the trailer module senses current and if it is low (like due to a bad connection), it will trigger this message.
For the Truck Side, you may try to pull and inspect 3 ea connectors
C405 & C4099 & C422
If its a bad connection on the Truck Side, its a high probability of a dirty corroded connection on one of the 3 connectors below.
C405 - RH Stop/Turn = Pin #15
C4099 - Back side of 7-Pin Connector
RH Turn = Pin #4
C422 - RH Turn = Pin #17
check fuse? there are different fuses for turn signals.
Fuse #87 feeds both LH & RH Stop / Turn for the Trailer Lights and controlled by the TRMtruck
If you are referencing Fuse 56 & 63 and the relays, so far no one has reported that they have those relays and fuses installed.
The wiring diagram shows them but they are for a truck that does not have the TRM installed, so far I have not seen a truck that does not have it, which is why I edited the diagram to show how its actually wired.
jflogerzi
Moreno Valley, CA
I just remembered I had this exact issue but in reverse. running lights were not working but turn signals were. replaced the fuse and bam working again. It was the PiTA one in the engine on the underside.
FerdRanger
FerdRanger
Ferdinand the Great
Central NY
no thanks
C405 & C4099 & C422
RH Turn = Pin #4
that is helpful, wish I had a lift. ;)
