The Upgraded LED Solution for Halogen Headlights
Status
Not open for further replies.
Brianj67
Brian
Canada
2021 Ranger XLT
Firefighter
Thanks for all of the info and opinion.
These Lasfit bulbs definitely have no clear cut off and I won't use them. More money wasted.
That being said, both my 2018 Frontier(last truck) and my 19 Civic had excellent cut off and down road light. The Civic low beams are Autoone LED and they are not expensive at all. Apparently not all reflector housings are built equally.
I'll probably spend the money on headlight assemblies one day unless I trade it before then. :)
OFC Ranger
Jack
ZR2
Light cut off is not the only problem. Glare / Spillage is.
Even if you achieve somewhat normal cut-off, that is not the problem, the below picture is what you are subjecting oncoming drives to. By physical design reflector headlamps are suppose to throw light everywhere. They are giant bowls with chrome plating.
Projector headlights are built with a focal point / dome housing design for a reason.
https://www.tacomaworld.com/threads/why-leds-should-not-be-run-in-halogen-reflectors.454371/
Status
