Tapping into dimmable lights circuit in cab?
Oingoboingoagogo
USA
2020 Ford Ranger Lariat
I'll go against the grain, I hate wire taps. I'd rather spend the extra few minutes actually splicing the connection together, even if its a 2 to 1 splice.
I've been using these self soldering connectors for years now, pretty much exclusively in any 12v work I do.
Thanks for the input. I solder most of my connections.
I'm a little unclear on how this particular type of connector would work for tapping into an existing wire though.
You cut the wire in half - and add the extra wire (switch) on one side of the connector- so one side will have 2 wires in the connector.
Oingoboingoagogo
USA
@Oingoboingoagogo which wire in the console did you end up tapping into? Did you have any issues with dimming?
Hey Sross,
I found it difficult to locate a good access point for the dimmed voltage without pulling out more trim, so I decided to leave things as is. The light doesn’t bother me at night. You know what they say: “wear slippers—you can’t carpet the whole world.”
