Sway Bar Nut
Av8or
Lariat Ranger, Cessna Skywagon
Hey all, I'm working on installing a levelling kit and I'm stuck at step 1. How do I get this nut off? This is the linkage to the swaybar. I got a breaker bar on it and it just spins the whole nut with the set screw in the middle... then I tried to get either pull out or send through the hex headed thread in the middle... but that started to strip, so I decided to call it quits before I got any further. Surely I'm doing something wrong here. Edit - Impact also just spins and spins.
On a separate note, why do they say to unclip the power steering 3 harness? 2 of the 3 were completely frozen in place for me and again... I didn't want to break anything.
Rp930
Denver
Hold the hex unscrew the nut.
I'm doing this in the morning.
Hi Av8or
Look at the center if the stud...It is a hex or a Torx. You need to engage the center before attempting the loosen the nut.
Av8or
Av8or
Any tool recommendations? Not exactly much room for a combination wrench to get in there since it's in a recess.
Rp930
Denver
You should be using a proper boxend wrench.
Rp930
Denver
Offset boxend.
quangdog
Kimball
Meridian, Idaho
www.youtube.com
2019 Ranger Lariat FX4
Box end wrench on the nut, allen key on the inner bolt. I've swapped my front suspension 2x now, and am finally getting pretty good at the process. ?
Wes Siler
Wes
Bozeman, MT
WesSiler.com
Writer
Anyone have specs or a part number for this nut? My driver side one...fell off last night.
Toronto, Ontario
2019 XLT SuperCab
Husband-Caregiver
See pages 1, 3, & 13in the attached guide.
It tells you all about……..wait for it………Deez Nuts!
