Super cab rear door alignment issue
My 2019 doors work just fine. And that's both sides. Guess I lucked out.
You have a pre-COVID build like me. Much better build quality and we have all the deleted items. ?
Ranger_Rocks
Wandering
Wanderer
2020 Lariat SCab FX4. After having a rear door rattle a few times on washboard forest roads, I learned to firmly (not slamly) close the doors from about 6" out using the handle indent midway up the door. Nice solid close with no more rattles.
Here
XLT
I believe there’s a lot of truth in that statement and I kind of feel bad for the folks who didn’t want to buy a “first model year” and waited. My 2019 runs like a champ and is definitely Built Ford Tough.
dinosplace
Dino
Toronto
2020 Ranger
I can definitely tell the door latch stressed when opening the handle as it feels tight when pull on the handle and the door slight pops open like it’s under pressure, unlike the passenger side. Your may be slightly better than mine. I’m sure door needs a little adjustment. The passenger rear door closed so nicely.
veedubtuner
Morgan
Tulsa, OK
2023 CG XLT Scab FX4 Ranger/2004 VW R32
VW Parts slinger
Didn't read though everything so apologies if it's been covered/fixed. A couple days after I took delivery I noticed that the P/S rear door was hard to close and I had to slam it to get it to close properly and the warning light not come on. Turns out the upper seal for the latch was all boogered and not allowing the door to close properly. So I took pics so I could show service the issue, then cut the seal that was giving the door issues. Temporarily fixed, till I got the whole panel and seal replaced under warranty at my first service.
Tom_C
Tom
Virginia, USA
System Admin, Retired
I'm pleasantly surprised with my 2020 Oct build... well, surprised may not be accurate, but I'm pleased with everything. Every time someone posts about a problem I check to be sure mine is OK, and I've never found anything wrong. The only deleted item is the 2 bed tie downs.
TJC
I have a May 2020 build, and I am missing the passenger floor mat locking nubs (or whatever they are called). I need to get around to ordering them. I don't like the floor mat slipping around.
dinosplace
Dino
Toronto
2020 Ranger
Thanks for your response. The seal looks okay but there’s a stiffener inside the seal on the body side to prevent cracking. Its position is off to the side of the striker and the passenger side it’s directly in front of the striker. Are you able to share your before and after photos
veedubtuner
Morgan
Tulsa, OK
VW Parts slinger
Unfortunately I deleted those pics long time ago or I would. I just looked through my history as well and I don't think I posted here about it with pics either, sorry.
Muscleford
George
Ohio north coast
Retired CFO
My 2021 has no anchor points on the passenger side either. My 2011 Ranger did not have any on the passenger side and neither does my 2014 Fusion. I don't think they put them on the passenger side.You will need to cut the carpet to install them.
Good luck.
TJC
Good luck.
I believe the 2019 models had them.
Chris M
Surprise, AZ
2021 Ranger XLT Sport 4X4
Security Supervisor
Good luck.
They were on the 2019 XLT trim, and maybe other trims.
My 2021 XLT does not have them.
